Hello awesome Figma makers, I’ve just upgraded to a pro account with full seat, but do not see the AI option in both iOS app and browser. In browser, there is an icon which looks like AI, but it seems to be a menu navigator only. I’ve also enabled AI in the admin settings. thank you
Both Figma library and site files are in the same project but can’t see the library I’ve just published as an available library to be connected in my site file.
Over two years ago, I launched the Quick Commands plugin — a tool that lets you run powerful shortcuts right from the action bar. Type “pt10” to set padding top to 10px, or “rb20” to set bottom radius to 20px. It quickly became a favorite among power users who value speed and precision — and I received tons of great suggestions along the way. Now, thanks to a bit of help from AI (which made maintaining the plugin way more efficient), I finally had the time to ship a major update! Two highly requested features are now live: Fuzzy Search: Can’t remember exact commands? No worries. Just type what you want and let the plugin figure it out. Custom Command Aliases: Create your own shortcut names that match your workflow and memory style. Give it a spin and let me know what you think! 👉 https://www.figma.com/community/plugin/1078657295141928162/quick-commands New settings panel: Custom Aliases: Fuzzy search demo:
Could you implement a feature that allows the AI chat to memorize the conversation and then archive it to clear all the history messages? It tends to get really laggy at some point when the conversations has been going on for a few days. This is typical in Chat GPT as well. But this needs to be sorted. When I work with figma make at the moment i haev to write all my updated request in a notepad document and then paste into the chat becuase its lagging so much. And if claude sonnet doesnt allow this workflow, come up with something else. Thanks in advance!
In Figma’s playground file for the (beta) AI features, there’s a hands-on example for the AI feature called Replace Content. It sports a (vertical) auto-layout frame with two similar objects. When you select the frame, a wide handle appears on its bottom edge (in the instruction called the Duplicate Bar) , offering the option do drag up and down and add multiple instances of the same object(s). It looks and works a lot like the Repeat Grid of Adobe XD – the only featured I missed now and then in Figma, so I’m a happy camper now ! 😄 The feature works very well, and the obvious next task of replacing the repetitive texts for uniquely generated dummy texts, also works very nicely BTW. But how did they get this Duplicate Bar to appear ?I can’t find anything about it in any Figma Help resources. Just this tidbit in the beta AI example. So I tried and tested it a bit, and it seems to me that you need at least 2 by 2 elements: 2 elements in one group or auto-layout, copied or duplicated into
Hi, I duplicated 2 files, a library and a design file. The new design file is obviously still attached to the previous library. I want to attach it to the new library. Everything is still exactly the same. I open the library panel in the new design file, add the new library to the file and detach the old one, then I click on “swap library” in order to replace components and styles in the file, but I get this error ID: ba6fb6fe90044b46a5917a85bf89e636. Did this happen to anyone else? If yes anyone found a solution? How am I supposed to swap my libraries if this doesn’t work, I tried more than 20 times over the week end.
Hi everyone, since the last update I’m experiencing issues with the copying of images into other frames. It seems like the image isn’t stored in cache. Does anyone know how to fix it? Best, Finn
In the current implementation of Figma’s Version History, timestamps are displayed in relative terms such as “25 days ago” or “1 month ago.” While this provides a general indication of when a change occurred, it falls short in scenarios where users need to locate a specific version tied to an exact date or time. Proposal: To enhance usability, I propose the addition of a tooltip that reveals the full date and time when hovering over these relative timestamps. For example, placing the cursor over “25 days ago” could display “17 June 2025, 14:43.” Although this solution may not be exhaustive, it would significantly improve the user’s ability to identify and retrieve specific versions with greater precision, all without disrupting the existing user interface.
TL;DR: Changes highlighted in version history snapshots. Scenario: I am working on a file with other designers and want to know what someone else did in the same file. I can pull up older version history, and see that someone else worked on the file on any date, but other than doing a visual comparison against a version that I worked on before to spot differences, I don’t know what they did. That leaves lots of room for missing something… As a collaboration tool, it would be very helpful if Figma did something similar with the history snapshots that a certain company (that rhymes with “poodle”) does with their Docs free online document editor. In the the case of Figma, when a collaborator looks at a snapshot in the version history it would highlight things that were changed in that version. It does not have to be every minute change so much, but things such as highlighting a layer that had changes made to it. Highlighting new frames that were created. Then bringing the screen focus to
It would be really nice if I could just search the version history to find specific saves, instead of having to scroll through the entire list. This becomes especially annoying if I have a lot of versions saved and am searching for a very old one. Search / Filters that would be nice: text search date filter creator filter
I’m sure that the page is extended to include the entire design content of my pages, but when I publish, some of them are fully viewable and others I can’t scroll to the bottom of them! Sometimes it’s just a little bit, and other times it’s a good 200px worth of content. I’ve tried different browsers and it’s consistent across them.
I have text styles defined inside a library file. All my components are using these styles. When creating the designs using the components and styles in another file I always make sure to use the text styles and if I paste text I use Shift + Cmd + V to esnure I’m pasting text without any formatting (verry annouing tho). Recently I was just going thorugh already done designs to check something and noticed that all the text layers in some of my pages are with the correct color variable, correct size and etc but they have no text style attached to them. Now I have to go layer by layer, copy the text, click Reset all changes (if it is a component) and paste the text. This is rediculous. So few questions: Is there any way to make the default pasting of text be without any format? Is there any bug that caused this dettachment? Is there any way I can only reset the style of the text layer inside component instance and not the text color and etc?
The recently introduced fill patterns do not seem to be correctly saved in styles: They are not editable (cannot select a new pattern object, and the toolbar does not show the pattern tab) When exported from a library, using them in another file results in displaying dots (presumably the default pattern)
I’m not able to select into the text layer to make text edits. I’ve read previous discussions from a few years where people have experienced the same thing. It might have to do with the mouse tracking speed change, but I tried adjusting that as well. Would anyone have updated solutions? Thanks!
Very low performance speed in Figma Make when the thread reaches large sizes (currently 230+ iterations). All actions in the chat area occur with a significant delay (typing, scrolling, etc.), making it impossible to work. However, the prototype itself works well within FM. Has anyone encountered this? What could be the cause? Could it be related to the power of the laptop?
Find answers, learn more.
