I'm writing to you with deep sadness and frustration. I spent a lot of time and effort working on a very important design project, and now I cannot access it because I lost access to the email address associated with my Figma account (ercander@lts.edu.pl). I still have the correct login email and password, but I cannot complete the login process because the system requires an email verification code—which I can no longer receive. I feel devastated that all my work might go to waste just because I can't access that email anymore. Even if you are unable to give me direct access to the account again, I kindly ask you to transfer the following project to my current Figma account: fatihyamak53@gmail.com 🔗 Habus Project on Figma This project is extremely important for a job application, and I worked so hard on it. I’m really desperate and hoping you can help me. Thank you for your time and understanding. Kind regards, Fatih Yamak
Hello Figma Support Team, I have been using the new Figma Make AI feature to generate designs, but I am unable to connect these files to Bravo Studio (and other third-party integrations) because: The files created via Make AI are saved as /make/ links, even after moving or duplicating them into my team/project. Bravo Studio (and most Figma plugins or APIs) require a /file/ URL to recognize and import the design. Even after attempting to move, duplicate, or export/import the file within the team/project, the file remains stuck as a /make/ link, not a /file/ link. This severely limits the usability of Make AI-generated designs in any real-world development or handoff workflow. Steps to reproduce: Generate a new design using Figma Make AI. Move or duplicate the file into a Team or Project (on Starter/free plan). Right-click and “Copy link” – link is always in /make/ format, never /file/. Try to use the link in Bravo Studio – receives “file not found or no permission” error. Expected behav
There are times when having sections free of constraints is nice… but my design team has become addicted to using auto layout with frames. In many cases when using sections, it would be amazing to perfectly space the inner sections out using auto layout.
I had a paid plan linked to a works email, in conjunction with another workplace account that I no longer used, since my address the the initial employer has been revoked I’ve also lost access to everything under the second account - and Figma is claiming the account never existed. I don’t know how or why they were linked, but I am now paying for an account I can’t access and have lost almost 7 months of design work. Please help someone, I’d really like to talk to a pro about this and get my old design files and paid for membership attributed to a different log in.
Not being able to use keyboard shortcuts in the variable collections menu/manager can really disrupt the workflow. Sometimes for example, because I’m so used to ‘ctrl/cmd+d’ to duplicate something, I try to duplicate a variable using this and accidentally end up duplicating something in my canvas. Just adding some simple shortcuts would improve the QoL and workflow with variables. Here are some quick examples: ‘esc’ to exit the menu ‘ctrl/cmd+n’ to create a new variable use tab/enter to choose which type of variable ‘ctrl/cmd+d’ to duplicate a variable ‘ctrl/cmd+r’ to rename a variable
Auto layout is cool. Thanks Figma! However, to change the display order, one has to manually change the order of each item in the Layer section, which can be annoying when dealing with too many items in the layout. A solution would be to add three layout buttons, right below the current ones, that do just that: reverse the order of display. Much love. I hope this helps! Names of the button and much more on it on my personal blog on Medium: New Figma Auto-Layout Feature. The Problem | by Malik D | Mar, 2024 | Medium
Merhaba Figma Destek Ekibi, Kayıtlı e-posta adresim olan ercander@lts.edu.pl adresine gönderilen doğrulama kodunu alamadığım için Figma hesabıma erişemiyorum. Maalesef artık bu e-postaya erişimim yok ve giriş yapmaya çalıştığımda doğrulama adımında takılıp kalıyorum. Yaklaşık 20 dakika önce önemli bir proje üzerinde aktif olarak çalışırken teknik bir sorun nedeniyle aniden oturumum kapatıldı. Bu proje, şu anda hazırladığım bir iş başvurusu için hayati önem taşıyor. Hesabımı kurtarmak veya dosyalarımın başka bir e-posta adresine aktarılması için acilen yardıma ihtiyacım var, çünkü bu çalışmayı kaybedemem. Lütfen benimle şu anki e-posta adresimden iletişime geçin: fatihyamak53@gmail.com. Anlayışınız ve yardımlarınız için teşekkür ederiz.
Hi, The Auto Layout settings section has disappeared from the right-hand panel in the desktop version of the app. I’ve thoroughly checked the entire panel, and the Auto Layout section is definitely missing. I then opened the web version, and everything is there — the section appears as usual. So technically, Auto Layout is working: the text inside behaves as expected, and I see the notification that Auto Layout was created. But the controls for it are missing from the right panel in the desktop version. Could you please help? Thanks in advance!
Hi, how can i add my catalogue pdf to figma sites.. , as you know figma sites connects custom domains via dns servers but there is no ftp access, so where can we load pdf files to show it in our web page ?..
We host the web page in figma.site servers , but i want to host my own html files in my server ? how can i get these files..
i didn't give any prompt today in figma make, still it is saying i am out of credit? how? i was trying to do it for 1st time!!
Bonjour, J’ai besoin de vos lumières concernant les licences Figma. J’ai actuellement une licence éducation qui va prendre fin bientôt. Malheureusement, à la fin de celle-ci, je ne pourrais pas investir dans une licence payante, car je serais sans emploi… Il m’est essentiel de garder accès au mode éditeur de tous les fichiers se trouvant dans mes Drafts. Pouvez-vous me confirmer, que si je garde la licence “gratuite” de Figma, je garderais un accès à mes fichiers présents dans le Drafts et que je pourrais toujours les éditer ? Par avance merci pour votre aide. Chloé
We’ve identified a bug related to how Figma handles overrides when switching between component variants in different orders. Specifically, when we first apply the variant where the dropdown is open, everything works correctly. But if we start with the dropdown closed variant and then switch to the open one, we run into issues:– The icon sometimes changes incorrectly– Occasionally, the button type also changes This issue isn’t limited to dropdowns — we’ve seen the same pattern affect many other components in our system. The bug appears to be tied to how Figma manages overrides based on the order of variant switching. We’ve attached a video showing this behavior in action. Please investigate, as this makes it hard to maintain consistency in large design systems.
Hi everyone! I have a problem with emojis disappearing from the thumbnails. As you can see the master file has a gemstone on the cover, but it doesn’t appear on the thumbnail. I designed it last year and everything was perfect, but now when I try to recreate this approach, the emoji just don’t show up on the thumbnails. What’s funny is when I copy the cover from the old files and copy it to the new one, everything works fine, but when I start making changes to the text frame in the copied cover, the emoji disappears from the thumbnail again. Things I tried to do so far: resetting the app clearing the cache building the cover again from scratch It seems like Figma completely lost the ability to show the emojis on the thumbnails for me. Any ideas on how to fix that? Anyone has the same problem?
Find answers, learn more.
