I was going to praise how neat the new Annotation feature is, when I realized the content is only visible to Dev Mode accounts. Are you serious? I understand you want to limit creating annotations to certain seat types, but viewing annotations should be a viewer-level feature. Come on Figma, there are better ways to convince your users to pay for a subscription. This is such a crooked move.
In Figma Buzz, there's an issue with exporting pages to PDF: the selected format doesn't apply to all pages. I select the desired pages, click "Export," then set the format to PDF in the right panel and click "Export" again. However, all pages are still saved as PNG files instead of PDF. Even if I manually change the format to PDF for the first or second page, the export still results in PNG files for all pages. The only way to get a multi-page PDF is to manually set the PDF format for each page individually. With many pages (e.g., 20), this is extremely time-consuming. It would be great if the selected format (like PDF) could automatically apply to all pages during export.
Within a file you can copy and paste frames with annotations while their tags remain but if you copy frames or components to another file, the annotations get copied which is great but their tags unfortunately disappear. Expected behavior: Annotation tags should remain if copy and pasted to another file.
In the past, there was a way to export selected framers into a single PDF, as described here: Since a recent update, this doesn’t anymore. And I can’t figure out how to make it. Any idea?
Good day!Why was the option Show behind transparent area removed in the Drop Shadow effect?This made the work very difficult ( [The title of this post was updated by a moderator from “It was good function” to “Missing ‘Show behind transparent areas’ option in Drop shadow effect” on 20-Jul-2025.]
About three weeks ago some of my PNG images suddenly appear grey in Figma, where there is semi transparency, and around the edges of illustrations. These are images I have exported correctly before. Now if they’re exported the grey shows in the exports as well. I have no clue as to why, is this a bug, some new setting I’ve missed or accidentally activated? Tearing my hear out over this, would be super grateful for help! :´D Top: screenshot from Figma, grey splashes should be white! Bottom: for comparison, as it should be, white semi transparent splashes.
I was looking for a plugin that could: Export multi-page PDFs Preserve internal links from prototype mode (so they work in the PDF, e.g. as a Table of Contents for ebooks) I found a few options, but they were paid. So I built my own - completely free. Today I published v2.0, which adds the ability to export PDFs in High / Medium / Low quality. If anyone has feedback, I’d love to hear it! Link to plugin: https://www.figma.com/community/plugin/1535371360850075397/figma-to-pdf-with-links-and-multiple-pages Figma to PDF with links and multiple pages
Figjam has the same crummy experience trying to copy a page/board as Figma does...you can’t just duplicate or move a board, you have to open the original, open a new blank file, copy and paste all content manually. It sucks. What is really being annoying right now is that images on the Figjam board are not being copied over even tho they are unlocked.
I am a student at INSAT (Institut National des Sciences Appliquées et de Technologie, Tunisia) and I am currently using my official university email address (@insat.ucar.tn) to access Figma. However, the system does not recognize my domain as eligible for the Education Plan. Could you please review my case and add @insat.ucar.tn to the approved education domains so that I can benefit from the Figma Education Plan? I can provide proof of enrollment if required. Thank you for your support
How can I remove an extra seat, that I no longer need, from my account. Thanks.
Currently, I have 7 full sheets as research on my professional plan, and it will be renewed on the 27th of this month. I want to renew only 5 full sheets when I renew because I need fewer sheets. How can I change it?
i cant share the links for some reason
last few months i used figma edu plan, now that plan has been expired. now i want to unlock my account and downgrade to free plan how do i do that?
When I draw a straight line, the coordinate of the line remains on the edge even when i set the stroke position to centre. This make it difficult to align perfectly. See this example where I am making a cross. Alignment is imperfect even when I use the align tools. You can see the bounding box of the line is on the edge rather than the centre. Can I fix this? Object aligns to the selection bounding box rather than centre of line. This is the result of align both lines with the position align options. I’m trying to make a perfect cross, this is the result.
What does it take to get Figma to answer a support request? Being dead in the water with things that don’t work as they are supposed to is bad look Figma. At least help us out.
Find answers, learn more.
