I’ve tried to create a webapp with Make to feature user authentication, progress tracking, and email delivery of PDF packages. This requires Supabase for user management, data storage, and API integration with Resend for email delivery. Now, whenever I get the Connect to Supabase window with the Setup your account prompt and the Connect button. I click Connect, get redirected to status=succedded page with Successfully authenticated response, but when I get back to Figma Make, the window still just shows Connect, not the other options after connecting. Is there anyway to clear and start over with the supabase integration? or am I missing something very obvious? thank you for any help!
Hello, I accidentally added Total Full seats. How can I remove them? I only need the dev account.
We're currently experiencing an issue with Google authentication in our Figma Make + Supabase setup. When a user attempts to sign up using their Google account, the user is successfully created in Supabase, but the OAuth callback URL doesn't work as expected. As a result, the user isn't redirected to the authenticated part of the application. This breaks the login flow, effectively preventing access to the app despite the user being created in the Supabase auth table.
I'm building a monthly newsletter from a detailed Figma design (custom fonts, images, links, pixel-perfect layout). Manually rebuilding the HTML each month isn’t an option. Is there a reliable tool or workflow to turn a complex Figma email design into responsive, Mailchimp-compatible HTML with minimal manual work? Thanks in advance I’ve tried: Emailify: completely broken Figma → Mailchimp export: completely broken Open Anima: gives clean HTML, but without images or links HTML-to-MJML converters: too messy, especially with 5000+ lines impossible with Stripo
When using dynamic strokes, the end point sometimes renders with a visible gap or an extended point, instead of rounded end. I believe this is a bug. Example of gap: Example of point:
I've been having a very weird issue in Figma recently. When trying to move objects in a Frame it blocks me for some reason, but it does let me move around a couple of objects on the top. Objects outside of this frame are able to be moved freely. And if I move the order in the layers section then it works (the frame has auto layout on).Does anyone know why this is happening and how to resolve this issue? https://imgur.com/a/PKxFTs2
Hi I am new and use the free version. I want to insert a table and I think I should use the plugin for the table creator? Biut in my list of plugins there is no table creator. I know the functions are reduced in the free version, but how can I figure out what is included and what not? Thanks!
I can no longer copy one line of CSS out of dev view. I now have to use the clipboard icon to copy all the CSS and paste it into my file, then delete what I don’t need. I have added stills showing basics. I am on a Mac Sequoia 15.3.1, using Figma in Firefox Dev 139.0b5. It seems to be ok in Chrome, but that is irrelevant, unfortunately, as process is dependent on Firefox Dev.
With the new update, we have a great new feature, but unfortunately, it’s not usable with our component structure. Exposing all props of a nested instance also exposes props that we don’t want in the context of the consuming component. What if we could also select which properties to expose? This would lead to a cleaner sidebar with only valid props.
I'm writing to you with deep sadness and frustration. I spent a lot of time and effort working on a very important design project, and now I cannot access it because I lost access to the email address associated with my Figma account (ercander@lts.edu.pl). I still have the correct login email and password, but I cannot complete the login process because the system requires an email verification code—which I can no longer receive. I feel devastated that all my work might go to waste just because I can't access that email anymore. Even if you are unable to give me direct access to the account again, I kindly ask you to transfer the following project to my current Figma account: fatihyamak53@gmail.com 🔗 Habus Project on Figma This project is extremely important for a job application, and I worked so hard on it. I’m really desperate and hoping you can help me. Thank you for your time and understanding. Kind regards, Fatih Yamak
Hello Figma Support Team, I have been using the new Figma Make AI feature to generate designs, but I am unable to connect these files to Bravo Studio (and other third-party integrations) because: The files created via Make AI are saved as /make/ links, even after moving or duplicating them into my team/project. Bravo Studio (and most Figma plugins or APIs) require a /file/ URL to recognize and import the design. Even after attempting to move, duplicate, or export/import the file within the team/project, the file remains stuck as a /make/ link, not a /file/ link. This severely limits the usability of Make AI-generated designs in any real-world development or handoff workflow. Steps to reproduce: Generate a new design using Figma Make AI. Move or duplicate the file into a Team or Project (on Starter/free plan). Right-click and “Copy link” – link is always in /make/ format, never /file/. Try to use the link in Bravo Studio – receives “file not found or no permission” error. Expected behav
Find answers, learn more.
