Hi, I just purchased a monthly figma subscription and I’ve tried to add pages within one of my projects and it is still saying that I need to purchase and upgrade. I can see my access is set to ‘full’ but I can’t add additional pages. I have also tried logging out and then logging back into my existing account. Please help! It’s urgent as I am in the middle of a job application test.
Hey Team, Since a few days I have been experiencing this problem where the code generation cuts off mid-way and then I receive this error “Try Again with fewer inputs". Funny thing is that Figma Make shows Version Success on the chat but in the preview section it shows “Build Error” and also “Error Messages” in the console. When I try to autofix these, the same issue occurs where the code generation process cut-off abruptly. This is happening randomly and at times, this whole cycle keep continuing. I have not been able to code or make any updates because of this. Its like stuck in a constant glitch. Kindly help me out
I am a user in Chinese Mainland, and my computer system is Windows11. Now I have a bad problem. When exporting frame and export layer in figma, fonts and graphics in the exported image have stroke lines, as shown in the figure. This problem has been bothering me for a long time, and I am eager to know how to solve it.
Hi! I'm Gee and I want to be UI designer by 2026. I just found myself drawn to it this week and my heart was beating fast at the thought of being one, the only problem is I don't know how to begin. I watched tutorial for figma and I finished it. Do you have any recommendations on how to be one? I'd be really glad if you could provide me resources. Thank you so much for reading up until this point. I really appreciate any insights that you might have. P.S I don't have graphic design or background related to UI.
In any other vector software, Snap to Geometry (or snap to point, depending on the software) means anything will snap to object points or edges. In Figma, Snap to Geometry doesn't allow me to snap a guide to just any vertex (point), only some points that are around the object's bounding box. It's even worse: some points only snap with horizontal guides and others only vertical ones, depending on the point's location. Try to snap horizontal and vertical guides to all points of a T shape, you will see the problem. It also doesn't snap other objects to these points… Actually it doesn't snap anything! Once I deactivated Snap to Objects the guides don't stick to anything anymore. That function is broken and it needs to be fixed.
Hi Figma team, I’m writing because I’ve just noticed a charge of $43.20 on my account, despite having cancelled all paid subscriptions well before the renewal date. To make matters worse, I received absolutely no email or notification warning me that a payment was about to be processed. This lack of transparency is extremely disappointing, especially coming from a company like Figma. On top of that, trying to check or manage my subscription and billing information is unnecessarily complicated. It genuinely feels like the system is designed to make it difficult for users to know where they stand, what’s active, what’s not, and what they’re being charged for. Frankly, it starts to resemble the kind of tactics used by less reputable services, even scammers: no clear way out, no notice, and a surprise charge you can’t easily stop. I’d like this payment to be reviewed and refunded immediately, and I’d also appreciate a proper explanation of how this was allowed to happen.
Is there a way to export an AI generated page into a regular figma design file and then edit from that?
When exporting content and detail heavy slides from Figma slides I am losing details and layers on the slide itself. It is only happening with exporting as a PDF however I NEED to export it was a pdf from Figma to ensure text can be read by AI. I have tried a few methods but none of them have provided me with what I need, if you have any tips or ideas that might fix this problem that would be great to hear!!!! Can you please help?
Dear Figma Team, I am a big Figma fan and want to fully transition from Adobe, I’ve identified two key text-related SIMPLE features that would greatly improve Figma’s layout design capabilities: Text Wrapping Between Text Boxes Figma currently lacks the ability to wrap text between multiple text boxes, making multi-column layouts cumbersome. A native text threading feature (like Adobe indesign) would allow text to flow dynamically between boxes, especially when resizing frames. Hyphenation for Improved Text Alignment Long paragraphs in Figma often result in uneven spacing at the edges. A hyphenation feature (like Adobe Indesign) would automatically add dashes to break words at line ends, improving readability and visual consistency. These features would make Figma more versatile for typography-heavy designs and streamline workflows for users transitioning from other tools. The community has been asking for this improvements for years and still we have not seen any response from you. Pl
Hi all, I've been using the Poppins font in my Figma Sites design, and everything worked perfectly for weeks. However, after logging in today, the font suddenly appears incorrect in preview or play/test mode, it looks like it’s being replaced by a different font or weight. This only happens in preview mode, not in the design view. Poppins is a Google Font, so I assume it should still be fully supported and available. Is anyone else experiencing this? Does anyone know how to resolve it or whether this is a recent bug in Figma Sites? In the meantime, does someone know why the projects text also dissapears in the play/test mode? I had a similar problem with teeth not appearing, while all was fine in the design fase. Thanks in advance for your help! Attachments:
Find answers, learn more.
