Luciano
Apr 10, 2025 2:19 PM UTC
Snap to Geometry doesn't snap guides
In any other vector software, Snap to Geometry (or snap to point, depending on the software) means anything will snap to object points or edges.
In Figma, Snap to Geometry doesn't allow me to snap a guide to just any vertex (point), only some points that are around the object's bounding box. It's even worse: some points only snap with horizontal guides and others only vertical ones, depending on the point's location. Try to snap horizontal and vertical guides to all points of a T shape, you will see the problem.
It also doesn't snap other objects to these points… Actually it doesn't snap anything! Once I deactivated Snap to Objects the guides don't stick to anything anymore.
That function is broken and it needs to be fixed.
Scott ONanski
Aug 18, 2025 1:46 AM UTC
Oy my goodness, I thought I was losing my mind.
Sometimes it snap, sometimes it doesn’t. lol
And, the fact that options are arbitrarily buried and obfuscated with no real logic or reason, other than the fact I clicked on “something”, is obsoletely maddening.
You know how hard it is to get work done when I have to try to decipher half documented features?
How the entire industry was convinced this was the go so software is beyond me.
The irony of it all? This UI/UX prototyping software has the worst UI/UX imaginable.
Seriously, this is something I expect from FOSS developers.
