We're currently experiencing an issue with Google authentication in our Figma Make + Supabase setup. When a user attempts to sign up using their Google account, the user is successfully created in Supabase, but the OAuth callback URL doesn't work as expected. As a result, the user isn't redirected to the authenticated part of the application. This breaks the login flow, effectively preventing access to the app despite the user being created in the Supabase auth table.
I’m currently working on a file that includes components from a design library. I see the button to “ignore autolayout” for any components that I add locally in the file, but it is not available for components from libraries. The only way to get it to apply it is to create a frame or group around the library component instance, add “autolayout” to that frame/group, and then ungroup. But then, I also can’t remove the “ignore autolayout.” This seems to be a bug.
Finding a dependable Dewalt 18V battery replacement online can be tricky with so many options available. Not all sellers offer genuine or high-quality replacements, which can damage your tools or offer poor performance. The best places to shop are trusted platforms like Amazon, Home Depot, and Lowe’s, where verified reviews and seller ratings help guide your purchase. Look for batteries that are certified, have overcharge protection, and come with a warranty. Avoid suspiciously cheap listings that lack brand transparency. Brands like Powerextra, Energup, and even Dewalt itself offer solid aftermarket or OEM options. Always check compatibility with your specific Dewalt tool model. Also, make sure the seller provides return support in case of battery failure. A good battery replacement should deliver consistent power and last through multiple charge cycles. Taking the time to research will save you money and extend the life of your tools.
Figma’s 100% is slightly bigger than my browser’s actual size. Is there a way to make them 1:1 pixel perfect size?
Good morning, We are embedding Figma prototypes all over the IBM.com domain and we have recently been notified by our web security team regarding the 3rd party scripts that are being loaded. Such as: Google tag manager, GA, Facebook Pixel and Naver…. Is there a way that these tracking scripts can be disabled when we place the iframe prototype onto our pages?
How am I supposed to delete a file that I published if I can no longer access the original since I deleted it long ago ? What I see when I have the file What I see otherwise
In the previous version i can able to paste the vectors as vectors from adobe illustrator but now it’s not working its getting pasted as image.. IS anyone facing the same issue??.. how to resolve this because that helps a lot
Hello, it would be nice to have the option to insert floating components inside text (like Emojis). Use case would be for signs or infos in complex dashboards. Its a hustle to do this now manually and also set kind of boundingboxes to sync different heighs of text and component. Regards
I’m hoping someone can clarify this for me. I used to copy objects from Adobe Illustrator with Cmd +C and paste them into Figma with Cmd +V, and they would arrive as editable vectors. I’m absolutely certain this worked before. Lately, though, every paste comes in as a flattened image instead of vectors. Nothing in my workflow has changed, so I’m starting to wonder if I’m losing my mind! Has Figma (or Illustrator) changed something recently? Is there a setting or workaround I’m missing? Any insight would be greatly appreciated. Thanks in advance!
Hey! How can I transfer the AI generated Prototype in Figma Make to Figma Design and continue editing it manually there?
I keep receiving the error: “Something went wrong. Please refresh or try again later.” I have tried to remediate the issue by: trying again a day later duplicating the file and trying again clearing app cache trying desktop vs web reverting back to previous builds No luck on any of the above. Any suggestions? Have I hit a max amount of prompts? Frustrating as I’ve reached a point in my prototype that needs fixes and it is locked up.
Currently, only Preview and Code edit modes are visible. Are additional editing modes accessible?
Find answers, learn more.
