hi, I made an overlay that contains a component with two states: Start and Enabled. Interacting with the overlay in Start state moves it to Enabled state. In the Enabled state, component has a Close button . On the Close button , I added actions close overlay set component back back to Start state When I run the prototype, the second action never gets executed. The component remains in the Enabled state when the overlay is opened again. If I switch the order of the actions, the component returns to Start state but the overlay does not close. Only the first action is being executed. For now, I’m trying to find a workaround but this is very annoying. Figma, please fix.
In my Figma mobile prototype, I have a bottom navigation bar set to ‘Fix position when scrolling’. It appears correctly in desktop prototype preview (with iPhone 14 device selected) but when I open the shared prototype link on my actual phone, the bar is not visible until I change it ‘scroll with parent’. How can I make it appear fixed and visible immediately on mobile?
Hi Figma support, I have an urgent issue to ask: Figma could not display a sticky bottom bar when I used “Fixed in place” ,absolute positioning and set my prototype to iphone 13 setting. The sticky bottom bar does not even appear on iOS iphone 13!! I’ve tried using Last on top and First on top canvas stacking. Both only works on android device but not on iOS device on mobile in prototype mode!! I read that iOS mobile browser dun accept positioning of Figma! How can I overcome it?
I create a concept in Figma Make and want to test it with the team and potentially with customers, but they can see my underbelly chat. Is there a way to hide the chat?
So, ive been using figma make for a few days now, and everything is absolutely smooth , getting amazing results, creating amazing flows, complex interactions, but starting from yesterday, my figma make became completely DUMB, every simple change that i make on the project, everything breaks, for example, i have a 3 tab design, with everything working fine, i asked figma make to remove 1 item of the accordion on the fist tab and the entire project breaks, the second and third tab simply lost their funcionalities just by doing this, ive tried just edit a text and still gettin this behaviour, everything breaks.Ive been asking consistently to figma make does not interact or interfere with anything else that im asking , but gettin the same faulty results.Dit anything change? why is this happening? do the IA getting dumber ?
Hello, it would be nice to have the option to insert floating components inside text (like Emojis). Use case would be for signs or infos in complex dashboards. Its a hustle to do this now manually and also set kind of boundingboxes to sync different heighs of text and component. Regards
Hello! 🤠 I was very excited to see the addition of Auto Layout Grid today! Having flexibility for both Rows and Columns at the same time is a game changer. That said, I immediately ran into not being able to set a column width to “Hug” within a table, which is a bummer. In the attached video, I want the “Audited By” column to Hug to the longest table cell content. I show both the current solution today, and what I am trying to do with Auto Layout Grid. I can manually adjust the width of the column, I guess, but as you can see, it makes it hard to ensure correct padding without a lot of careful tuning of the width. Anyone have any solutions? Will this be coming as a fast-follow feature? Thank you!
I was super pumped to start using grids for my layouts until I learned of one fatal flaw that killed my excitement :( The inability to set a row height to hug is simply a deal-breaker for me. Also no variables support for gaps? really?
I tried Figma MCP when it was presented - and everything worked perfectly, but previous week it stopped responding for most of my models, but for some it randomly gives something. Actually it doesn’t work for me as it worked previously. Does anyone knows what’s the issue and how to resolve?
The built in UI-Kits don’t seem to allow for switching appearance modes anymore. when ever I try to switch to dark mode nothing happens. my personal libraries still work.
I’m currently working on a file that includes components from a design library. I see the button to “ignore autolayout” for any components that I add locally in the file, but it is not available for components from libraries. The only way to get it to apply it is to create a frame or group around the library component instance, add “autolayout” to that frame/group, and then ungroup. But then, I also can’t remove the “ignore autolayout.” This seems to be a bug.
Today I noticed that when I try to apply variable modes to page / artboard / layer using Figma on web they won’t apply. I select the option and nothing happens. I use this feature frequently, and it’s working in the desktop app, so it seems like this is a new problem. Anyone else experiencing?
When I use the /v1/file endpoint to retrieve the file data vie REST request, in the effects property of a node i cant see the relevant properties for the glass effect: { type": "GLASS", "visible": true} Is there any option to get the properties that are also available in the PluginAPI or a timeline when this data is present in the REST Api? Thanks, Felix
Hi, I have a side panel with buttons, and when clicking on one of the categories, the main screen slides to the correct categories. This works great. The buttons are in variant components with three states (default, hover, and selected). When I click on the button, I have two interactions set up in the prototype: ‘scroll to’ (to scroll to the section) ‘change to’ : state = selected My issue is that I want the button to go back to the default state when I click on another one. Is there a way to do that? (for now, they all become selected when I click one after the other). Thank you in advance, Anaïs
Find answers, learn more.
