YXGroup
Aug 13, 2025 2:34 PM UTC
Figma Make getting worse ?
So, ive been using figma make for a few days now, and everything is absolutely smooth , getting amazing results, creating amazing flows, complex interactions, but starting from yesterday, my figma make became completely DUMB, every simple change that i make on the project, everything breaks, for example, i have a 3 tab design, with everything working fine, i asked figma make to remove 1 item of the accordion on the fist tab and the entire project breaks, the second and third tab simply lost their funcionalities just by doing this, ive tried just edit a text and still gettin this behaviour, everything breaks.
Ive been asking consistently to figma make does not interact or interfere with anything else that im asking , but gettin the same faulty results.
Dit anything change? why is this happening? do the IA getting dumber ?
ksn
Aug 13, 2025 3:48 PM UTC
Hey ​@YXGroup - sorry about this. It sounds like the behaviors of Figma Make has gone down on your end, and I’d like to learn more.
First, would you be willing to share edit access to + the names of the file[s] you’re using Figma Make on? This is immensely helpful. It allows both our support and engineering teams to run diagnostics to see if there’s any errors that are happening on the backend. If you can do that, please do so with support-share@figma.com. You will not be charged for doing this.
I have to apologize again, but I’m having trouble understanding where things are breaking  so can I get a bit more clarification?
What is the ‘one item’ you’re trying to remove in this specific example?
What functionalities are breaking?
Can you provide examples of what you’re asking Figma Make to provide you? And then also the follow-up queries that you ask?
Also -- if you can provide a full screen recording of what you’re seeing, that would also be super appreciated. The visual would be great to compare to the file you have.
Let me know - thanks!
YXGroup
YXGroupAuthor
Aug 13, 2025 5:37 PM UTC
Oh Hi, !!! Thank you for your repply, im gonna provide all the archifacts and send it to the email provided,
ksn
Aug 13, 2025 7:39 PM UTC
​@YXGroup Oh! Could you actually send your detailed info over to me in a PM? The support-share@figma.com email address is only used to share files with.
If you send the details you’re emailing over to me (including the file names you’ve shared edit access to), I’ll get you some expedited help on my end.
design.animastudio
Aug 13, 2025 9:16 PM UTC
I am also having this problem. My Figma Make is so dumb it`s totally frustrating. It wasn`t like this at the start.
YXGroup
YXGroupAuthor
Aug 14, 2025 1:39 PM UTC
ive just sent you a PM with the details and screen capture
YXGroup
YXGroupAuthor
Aug 14, 2025 1:40 PM UTC
thats what im saying, somehow, on a blink of an eye, it became dumber and faultier
ksn
Aug 14, 2025 3:16 PM UTC
​@design.animastudio sorry you’re having a poor experience as well. I can assure you we are looking into improvements to Figma Make and AI, so more details from you would be helpful as well.
Please share the URL of the file[s] where you’re seeing these issues, and grant edit access to support-share@figma.com by filling out this quick form: https://figma.bot/submitreport. This won't impact your billing and will help us reproduce and investigate this more effectively.
Please drop any details on what you believe has changed specifically (or any other notes you think are relevant).
Thank you!
design.animastudio
Aug 14, 2025 4:17 PM UTC
Thank you!
I’ll be sharing the file in the form you sent (under another e-mail, because I’m having this issue on another account), but basically it falls into a loop constantly.
I have a list, each item with it’s own picture, and a user profile image on the top of the screen. Either the image of the first item of the list or the image from the user profile breaks. When I ask it to change one, it breaks the other.
I tell it to remove the correlation between these two images, because when I change one, the other shouldn’t even change in the first place. The AI tells me it’s fixed and won’t happen again, but it keeps happening over and over again. And there’s the loop. I couldn’t get it fixed so I gave up.
ksn
Aug 14, 2025 4:36 PM UTC
​@design.animastudio Sounds good - can you PM me the email you’re having the issue on? I’ll make sure it gets escalated on my end.
design.animastudio
Aug 14, 2025 4:39 PM UTC
Just PM’d you. Thanks for the response! =)
