課題:PaddingやMarginなどレイアウトを調整する際、つい全角で数字を入力してしまうことがあります。しかし、こういった場合、毎回変換キーを押して全角→半角に変換するか、最初から入力し直す必要があり、少し手間です。 提案内容:数字を自動で半角に変換するオプション --- Problem: When adjusting layout values like padding or margin, I often end up typing numbers in full-width (Japanese input). To fix this, I need to manually convert them to half-width or retype them, which is a bit inconvenient. Proposal: Add an option to automatically convert numbers to half-width.
Hey there! I was also wondering if it is somehow possible to include also the layer of variant controls to be exposed or hid! I often have cases where I need to nest base components e.g. an icon wrapper providing me with the ability to select certain sizes, or color overrides and boolean props of an icon. I am now able to expose all of those or none, but I can’t restrict the users to only be able to select just some of those. What do you think about it?
If I change the icon in a button and then change the state of a button from default to hover, the icon color does NOT change. (works fine if you don’t change the icon)I’m using stroke icons, and the scope settings in the color variable is set up to handle stroke. Please let me know what I need to do to so the swapped icon will change color on override.Video: https://monosnap.com/file/RUUxOXXXdznZoemEG4Aow5wO4As8Vx
I have created a badge inside Figma, and it consists of two elements. The background element is positioned at x:0, y:0, and the foreground element is centrally positioned in respect to the foreground element. Both elements are using integer values for positioning. When I go to the export menu I get the following error messages: Origin not aligned to pixels. Origin snapped to (-5, -16). Dimensions may expand by a pixel. I get those messages regardless whether I'm exporting as PNG or SVG. When I export the work as a PNG everything from Figma gets preserved on that PNG image, but the problem starts s when I export the work as an SVG. When I do export it as an SVG file and I open it in Inkscape or I use it as a component on the website, it gets messed up. The gradient from the badge does not get preserved, the edges become rough, and it doesn’t look like an SVG element but rather as a low quality jpeg file. Then I have created a completely new file in Figma and draw a triangle shape inside
Hi, I have lost an important file on Figma and I can’t find the file in any of my projects section or in the deleted section. It just disappeared completely and when I tried to access it through a past link, I am getting the following message: You can’t access this resource Contact the owner, an admin, or support for assistance. (Screenshot attached). I have a ton of my work in it and the file is very important to my work. I hope you could help me retrieve it. Thank you in advance,
Hi, I’ve placed a component with a variant (an expanded dropdown on click) within another component (a form). When I place an instance of my ‘form’ component into a frame the dropdown variant doesn't prototype correctly, it appears all squashed/distorted. Does anyone know why a component would stop working once it’s nested within another component? Thank you
Good day, I ve started to use figma make today and created very good things until ı ve updated a code of a design and it gave some kind of error on the interface preview,the interface started to lag and finally when ı press the fix 10 problems ,smoothing thing out screen came into action as always but ıt goes into a eternal loop and doesnt fix or code somethnig.It is stucked. I would be glad if you help me with this problem.
I love the intuitive “Ready for Dev” switch to signal a handoff state, and the working mode it provides our engineering partners. Before this state, however, we also have a need to review, incorporate, and track content updates. Related, there is also a step that requires regulatory review and approval. It would be interesting to see additional modes that cater to our other partners, much like “Ready for Dev”. I realize our content and legal/compliance partners can comment directly, but would be great to have a dedicated space for them to enter and track changes, before we hand off to engineers.
Hi everyone, I used to copy an image (Ctrl+C from browser or local folder) and then paste it (Ctrl+V) directly into an image component in Figma - like for cards or avatar images - and it would automatically replace the image. But recently, this no longer works. When I try pasting, nothing happens. Now Figma only shows options like “Upload from computer” or “Make an image” (screenshot attached). I’m wondering: is this a recent change or bug in Figma?Is there still a way to paste an image directly into a component without having to upload it manually? Thanks in advance!
Hey guys,UI3 has come a long way, I remember it was absolute crap in the beginning, it’s actually pretty cool now. But somehow, it still feels like the UX is not perfect. Maybe because all the sections in the right side panel rely too much on text? The structure makes sense, but I often find myself editing the corner radius for example, when in fact I want to edit the auto layout padding. That’s just one example, I feel that in the previous version I didn’t rely on reading as much, but mostly on reaction, which was instant.
My Make workspace has crashed. I asked Claude Sonnet 4 to create a more tech-style design for my page, and I believe it added too many elements when generating the landing page. Now everything is stuck, the page won’t load, Make is completely unresponsive, and when I try to revert to a previous version, nothing happens. This is urgent. Please help me fix this or show me how to solve it myself. Just to clarify, this is not an issue with my computer. I’m using a high-end setup with a 4060 Ti GPU, and everything else works perfectly, including programming other pages. Thank you in advance.
Very frustrating….I did nothing and a warning sudden pop up. The file tab automatically disappear. It’s not in trash either. What should I do now?I lost access to: https://www.figma.com/file/rL3TA1oinJin6i5R3MbWYr?fuid=565700342330813971
Download code button I spotted the "Download Code" option in the upper right corner of the editor, but I noticed that there is no "package.json" file. Is there any documentation or a way to run these projects locally using my own IDE?
Find answers, learn more.
