Figma Make Eternal Loop Problem "Smoothing things out"
caseni
Good day,
I ve started to use figma make today and created very good things until ı ve updated a code of a design and it gave some kind of error on the interface preview,the interface started to lag and finally when ı press the fix 10 problems ,smoothing thing out screen came into action as always but  ıt goes into a eternal loop and  doesnt fix or code somethnig.It is stucked. I would be glad if you help me with this problem.
  • Figmate
  • 2316 replies
  • July 22, 2025
Hi ​@caseni
I understand you're experiencing an eternal loop issue in Figma Make after pressing "fix 10 problems."
To allow our team to investigate this further, could you please fill out this quick form: https://figma.bot/submitreport .
In the form, please share the URL of the file where you're seeing this issue and grant edit access to support-share@figma.com. (Please rest assured that granting this access will not impact your billing.)
This will provide our team with the necessary access to better understand and address the issue.
caseni
  • July 22, 2025
Thanks for the quick reply, ı ve filled the form and invited support-share@figma.com  to edit.Waiting for you to fix my problem so ı can proceed my project.🙏🏾
caseni
  • July 22, 2025
Still waiting for your help 🙏🏽
caseni
  • July 22, 2025
and ı cant export my file as zip,html or css.I have to proceed my project.
  • Figmate
  • 2316 replies
  • July 23, 2025
Hi there,
Thanks for checking in!
I can confirm that our team has received your report and is already working on this for you.
It looks like our Technical Quality team has received your file via the report and successfully reproduced the issue on a duplicated file.
As our Technical Quality team has directly replied to you, they've flagged the "Smoothing things out" screen issue to our engineering team, and they are actively working on it.
Please keep an eye on your ticket for further updates from our team.
Note: To help other community members who might be experiencing the same issue, I'll updated your post title to include 'Smoothing things out'.
