Hi all. I have a couple of frames that have placed image in. I want to export as .svg format. I can see the image in the preview and on the preview of the .svg. But when I open the .svg in adobe illustrator the image isnt there and just should a blank box… Any ideas? It worked fine in sketch before.
Awaiting SSL certificateYour DNS records were validated. Once Figma issues your SSL certificate, your domain will be securelyactivated. Please check back later.
When variables are applied components look differently (see image – the bottom component is higher and the setting is the same). Figma does this on almost every component with paddings, height even radiuses are different than designed.
i know this has been posted before, but Figma really needs to address this issue. pasting an email address should not just format the existing text as a link with the new text as a destination. when creating prototypes with lots of dummy accounts, or even with real data, copying and pasting lots of emails becomes the hardest part of my day, and there are no key shortcuts either. i have to copy, then right click, paste to replace. or “copy as text.” it’s obnoxious, and frankly i don’t think anyone using Figma has ever needed a functional email link for a prototype, it’s not like we’re creating live products where someone might actually click the email link to send an email. please fix this Figma, it’s infuriating and breaks the flow of creating prototypes. When basically every prototype i create for work requires a list of users and their contact information, it becomes a daily problem which destroys efficiency. at the very least, allow us to paste them without formatting using cmd+shif
Hey there, im trying to fix a bug in my current Portfolio preparation. Ive used several frames that stay sticky at the top boarder and stack up on top of each other. However one components of the bottom layers stays clickable when hovering on that exact area of the frame even when it´s covered by the upper layers. I'll attach a short video to showcase the problem, you can find it via this retransfer link for the next 3 days https://we.tl/t-XyGD6vKI3O i hope somebody has a solution many many thanks already :)
We have a design system set up with tokens (variables) to enable all components to switch between light and dark mode. For developers/viewers to see what a screen should look like in Dark mode, we have to duplicate that screen. But as an editor I can set the colour mode variable at the Page level to Dark and all screens on the canvas/page turn to dark mode. If developers/viewers could also do this, I could delete the dark mode duplicates of every screen and only have one copy of each screen, defaulted to light mode, and then just toggle dark mode as needed. This would be much more efficient on memory usage and maintenance.
After letting my previous student plan expire and not using Figma for a while, I tried reapplying for one with the same account I had used to apply for the first student plan (around like 2020). The account logs in via Google and because of that I don’t think you can change the Figma account’s connected email(?) and so I tried to just reapply with said google log-in. This failed, so I tried making a new account with the school email and reapply. This time it worked, but I was wondering if I could somehow move the plan to the old account or maybe easily migrate old work / ownerships of projects? Thanks.
Whatever I try, I can’t seem to work with .mov or .webm videos with transparent background on Figma. Whenever I upload them, I get a black background. Am I doing something wrong? Or is there a workaround for this?
Hi, I recently logged into my Figma and it shows I’m on the Education plan but I'm not sure what is the expiration date. I read that it lasts for 2 years, but is it possible to know the exact date as I don’t want to suddenly get logged out from my school project while I'm in the midst of it. I tried asking chatbot and it says I’m on a starter plan. So I’m a bit confuse and unsure.
This is odd behaviour in my mind!When i select an item and use the scale tool, it makes the new size its default 1x when i reselect that element. Example: I select an image, set the scale to 1.2x, go about my business, return because i want to return that item to it’s initial 1x scale, increase or decrease it. The new size has now been set as its default 1x. and now i have to do math! Why wont it just remember that i set it to 1.2x? This behaviour is weird and makes me wanna use scale less!
I love the MCP project but am having a really hard time getting good results from it, every time I asking Claude Code or Cursor to style my UI component like the provided link it’d not even close, it was 85%-90% wrong, sometimes really wrong. Making it mostly unusable. Lots of experience with LLM coding, I know what I’m asking for it with-in their capability. I also recently tried Figma Make where I imported the exact some component, using the exact same prompt and it completely nailed. Figma Make using Claude Sonnet got all the colors right, the fonts sizes, added the exact stroke and rounded corners, it even added roll-over state and correctly guessed my design intent, really amazing! But when I do the same with Claude Code and Figma MCP but it completely fails, adding styles to the wrong components, getting all the fonts wrong, colors are all over the place, etc. I have some theories as to why but would love some feedback and help Theories 1. Tailwind vs traditional CSS - My first t
I tried Figma Dev Mode MCP server with GeminiCLI. Seems that the get_image Funktion can be called but Gemini reports an issue with saving the fileDo you know if it is a Figma Dev Mode MCP server issue or a Gemini CLI issue?
Hi, I created a menu like component, i created variants and link this , it is for a landing page, like top bar. This works when you don't link another animation like scroll .I want this menu to change when I push the name section of the page and scroll to the section page, for example when clicking in “Nosotros” scroll to nosotros section and is put in bold “Nosotros” at menu. thanks in advance, sorry I am not native English speaker, but try my best.
Where to see all the figma resources that i liked in community?
Find answers, learn more.
