I have text styles defined inside a library file. All my components are using these styles. When creating the designs using the components and styles in another file I always make sure to use the text styles and if I paste text I use Shift + Cmd + V to esnure I’m pasting text without any formatting (verry annouing tho). Recently I was just going thorugh already done designs to check something and noticed that all the text layers in some of my pages are with the correct color variable, correct size and etc but they have no text style attached to them. Now I have to go layer by layer, copy the text, click Reset all changes (if it is a component) and paste the text. This is rediculous. So few questions: Is there any way to make the default pasting of text be without any format? Is there any bug that caused this dettachment? Is there any way I can only reset the style of the text layer inside component instance and not the text color and etc?
The recently introduced fill patterns do not seem to be correctly saved in styles: They are not editable (cannot select a new pattern object, and the toolbar does not show the pattern tab) When exported from a library, using them in another file results in displaying dots (presumably the default pattern)
I’d like to insert an image into a cell in a table in FigJam so that it moves with the table as it expands and changes size. Currently, I’m just having to drag pictures around with the table as it expands which is fine for one or two images but I have many!
I’m not able to select into the text layer to make text edits. I’ve read previous discussions from a few years where people have experienced the same thing. It might have to do with the mouse tracking speed change, but I tried adjusting that as well. Would anyone have updated solutions? Thanks!
Hello, As a designer, I would love the ability to customize the icon and color of my pinned design files. I have multiple pinned files, and currently, I have to hover over each one to know which is which. Being able to visually distinguish them at a glance would improve organization and workflow efficiency.
Very low performance speed in Figma Make when the thread reaches large sizes (currently 230+ iterations). All actions in the chat area occur with a significant delay (typing, scrolling, etc.), making it impossible to work. However, the prototype itself works well within FM. Has anyone encountered this? What could be the cause? Could it be related to the power of the laptop?
Double-clicking a text layer won’t let me edit it. The layer is not locked. This issue seemed to be resolved in past for other users, but the solution has not been mentioned in the thread. I am first time coming across this issue. Please guide.
I created a new Slides template, but I’m still only seeing the default stock slides in the “New slide” dropdown. I’m not sure how to remove those and add my own custom slide layouts. I’m also unclear on how to create or edit a template style, including setting custom colors and text styles. The deck defaults to the “Light Slides” style, but I don’t see any options to edit or add a new template style. I’m on a company plan and appear to have full access to Figma Slides. Any help appreciated.
I have been using Figma Make to design my portfolio which was going great. Things I got done - Created a homepage Added Interactions Defined a visual design language As I am proceeding to drilled down pages further, I have noticed a few things : The images that were added previously are deleted / replaced by new ones - despite specific instructions to not do it. Slow speed : I also noticed that the typing speed of prompts slowed down as I proceeded further - cross-checked if it was a computer issue (which it wasn’t) It’s forgetting things! with every prompt & design updates, it’s now deleting the previous content + pictures :( all the hard work seems to be going in vain and I’m not afraid to touch the project in fear of disrupting the progress so far Can someone help me? Also, what’s the memory capacity of Figma Make? I noticed it was using Calude Sonnet so, assumed it should have been good. Am I missing something here?
So, people were asking for more undos… because 100 wasn’t enough. So heeey - what a great idea - you turned it into what - 20 undos? 25? WHAT THE F...IGMA? heh
When using “Undo” I want to undo changes not “clicks” or selections. Yes, this is addressed in several threads, but this is one of the reasons Figma is so frustrating, that I seriously considers changing job to a company NOT using figma. Funny how a UX design-tool can have a terrible User Experience. Question: Will and When do we get this fixed?
Find answers, learn more.
