Has anyone found a way to have a color variable for bulk create in Figma Buzz? For example, I have an ad. I want to make 5 variations with different background images. I also want each ad to have a different font and button color. Do we think there will be an update down the road to make these edits in the google sheet for bulk create or will it need to be done manually after creation? Am I missing something? Thanks!
Hi Community, I am trying to create a hamburger menu that when it expands - opens to show page titles it moves the content - page title / breadcrumbs down underneath it any ideas !? Included some images of the interaction I am trying to recreate… CLOSED OPEN
Hi Figma, Could the right panel stay fixed when the left panel is hidden? I'm not sure why it switches from fixed to floating. Also, when I zoom in on an element with the left panel hidden, parts of its area gets hidden behind the floating right panel. Is that the expected behavior? I've attached a video below to add more context.
Hi everyoneI’m facing an issue with one of my files in Figma. I’m the Team Owner, but the file has somehow become ownerless after trying to move it from Projects to Drafts and back. Now it just shows no owner, and I can’t find any option to reclaim it, even though it’s inside my team space and I have “can edit” access. I contacted Figma support, but the AI assistant said ownerless files can't be claimed directly, only ownerless projects can. It also mentioned that I can still edit the file or grant access to others, but that doesn’t help with actual ownership. Has anyone experienced this before?Is there any workaround or way to properly reclaim ownership of a file in this situation?
When I click update to update my branch with the main file, I get this prompt. This just started happened within the last 2 weeks or so. This is unique to me, my other team members are not having this issue. thanks
Before you used to be able to command click on an entire frame and it would collapse all groups inside the frame and the frame itself. Now if I have a frame that has 100s of layers and layer groups and I am trying to find a specific layer, I can’t collapse all folders easily to find the correct layer group.
My dev mode is not starting even if ive verified my student account.
I remember there used to be an option to download the ZIP from Sites and Maker, but I can't find it anymore. Did they move it or remove it?
Say hi and let the community know where you’re from, what you do, and anything else fun you’d like to share. 😊
I am creating an ‘infinite’ photo gallery. Basically a grid of images in various orientations that extends in all directions. I am creating empty rectangles to make the grid shape and then have other people paste their images into each rectangle. The problem I am having is a lot of the rectangles were rotated so when the image is pasted into it, the image is also rotated. Is there a way to make all the rectangles ‘forget’ how they have been rotated and just work as a regular container for the images? thanks
Hi there, I’m Joo, a designer contributing to the Cursor-Talk-to-Figma (CTTF) project. First of all, thank you for releasing the official DevMode MCP — especially the image extraction feature. We’ve been successfully combining DevMode MCP with our plugin API-based third-party MCP to automate many workflows, and it’s working really well. However, I’d like to report a recurring issue when using the get_image tool. In our setup, we typically use Figma’s get_image to extract visuals, pass them to an AI agent for analysis, and then follow up with tools from CTTF — such as UX writing or critique. But as shown in the screenshot below, we consistently run into an error when calling get_image. While hitting “Resume” does allow the process to continue, the repeated interruption creates some confusion. Any idea what might be causing this? Should I raise this with Anthropic as well? Thanks in advance!
Find answers, learn more.
