I guess it’s a tiny thing but it will be super helpful to have an option with each element to remove it from final exports. Like sometimes I have some elements which I don’t want to be in the final export when I am batch exporting multiple frames. Fo
Hi there- I went to login to my paid Figma account and couldn’t remember my password since refreshing my cache, so I decided to login with my Gmail to save time. When I did, it briefly flashed me my existing account with my previous work, before then
Hi!We are currently investigating a way to use the same design system for all our different sub-brands (as they have a lot in common). To do this, we have created a small working group where I am one of the members.The result will be some kind of POC
Using glass effectUsing background blur
Hi all,Have you considered adding a feature to the auto layout “gap” feature that could allow a user to set a minimum gap i.e. 8px and a maximum gap i.e. 40px?I’ve recently needed this function for building bar graphs. I need to make them responsive
I am trying to push my site to Github but it seems to indicate that there is a security issue. I have tried to recreated my repository and nothing seems to be working. The connector appears to say that it is properly connected but then the AI chatbot
The controls for component properties appear twice when in slides mode. Not the end of the world but kinda annoying to work with some dropdowns. Surfacing this as it does not look like intended behavior.Card in design modeExact same card in slides mo
Hi eveyrone,I’ve started by drafting/prototyping in Figma Make, and have moved things forwards really quickly. I’d now like to move the screens into more of a workable space where I can see/edit all screens to take them from initial concept to my own
Components added from libraries in the sidebar are added above the frame and not contained within the relevant frame. This means that you need to navigate back to the layers panel to manually place the component within the frame every time.Open desig
With the new update, we have a great new feature, but unfortunately, it’s not usable with our component structure. Exposing all props of a nested instance also exposes props that we don’t want in the context of the consuming component. What if we cou
Simple as the title : Allow components to be set as file thumbnails. We need that possibility in our company to be more flexible with our thumbnails, wich may change year by year.
Find answers, learn more.
