Jeff_Jin
Jul 21, 2025 1:56 AM UTC
Bug: The glass in the effect style is missing
After setting the glass style attribute and adding it to effect style, the effect style will soon become empty, resulting in the loss of the glass style.
Junko3Solution
Jul 22, 2025 2:12 AM UTC
Hi there,
Update: Our engineering team has deployed the fix for this issue. Please refresh Figma and give it a try.
Thanks for flagging this to us!
Tom Reem
Jul 22, 2025 12:29 AM UTC
Hi ​@Jeff_Jin — thanks for flagging this!
I’ve touched base with our engineering team, and they’re actively investigating the issue with glass effects not saving correctly. We’ll share updates here as soon as they’re available. Really appreciate your patience in the meantime. 🙏🏻
Junko3Solution
Hi there,
Brandon_H
Jul 23, 2025 6:41 PM UTC
It still isn’t working for me. I updated Figma and Refreshed.
Aug 11, 2025 5:23 PM UTC
Hi ​@Brandon_H, thanks for following up about this issue and apologies for the delayed reply!
Are you still having issues with Glass styles? If so, are you able to send a bug report to our technical quality team here? https://help.figma.com/hc/en-us/requests/new
Please share an example file and add support-share@figma.com as an editor. (Don’t worry - this won’t affect your billing.) We can have our team take a closer look at what’s happening for your specific file, since this issue should have been fixed on July 21st.
Brandon_H
Aug 11, 2025 5:39 PM UTC
Hi ​@djv, the issue seems to be resolved now. Thanks!
Aug 11, 2025 6:06 PM UTC
Glad to hear that, ​@Brandon_H!
Please let us know if you run into any further issues.
Juan Pablo
Aug 25, 2025 9:43 PM UTC
Hola buenas tardes,  quería usar el efecto glass pero no me aparece activo, me gustaria saber si tienen alguna solución, quedo atento a sus comentarios
Aug 25, 2025 10:14 PM UTC
Hi ​@Juan Pablo, thanks for reaching out!
I don’t speak Spanish, so I hope it is ok that I reply in English. What layer type are you attempting to apply the Glass effect to? Is this happening in all your files or this one file in particular?
Do you have any issues applying the Glass effect in our Glass Effect Playground file?
With a few more details, we can work together to find what may be causing the issue.
ejqs
Dec 19, 2025 5:56 AM UTC
I found that the reason for this is because the element is not in a frame. Once I frame selection, glass becomes available.
