Hey everyone, I've been experiencing a persistent bug with the Scale tool (K) that's significantly interrupting my workflow. Here's how it normally works and where the bug occurs: Expected Behavior (Working as intended): I press K to activate the Scale tool. I scale the object. I press Escape or Enter to apply the changes. The tool works perfectly. The Bug: I press K to activate the Scale tool. I scale the object. Instead of pressing Enter/Escape, I click anywhere else on the canvas to deselect the object or shift focus. (This is where I suspect the tool enters a 'limbo' state; the panel reverts to normal, but the scale tool isn't properly closed, even though this behavior worked fine previously.) When I then try to use the Scale tool (K) again on any object, the anchor point squares (the small boxes that control the scaling origin) turn grey, and the tool completely stops functioning. Clicking on anything doesn't re-enable it. Workaround: The only way to fix this is to reload the Figm
Was working on a file and switched from windows to mac. After logging into Figma from mac, cant seem to find the file i was working on and the sharing link that I generated previously does not have access. How is this possible when I am the owner of the file? Please help. This is the link to my file: https://www.figma.com/design/LHYzcvxXLO85KsTAzcfphT/CPUI---GE?node-id=1-21&t=CLLSPgJobIKupwrc-1 I am using SSO login on figma.
Hey Peeps, Right now my Figma Make is connected to one of my Supabase account which has two of my projects. But I have created a new Supabase account for newer projects, but Figma Make is not allowing me to disconnect the current integration and login or connect to another supabase account. Is this a limitation or can this be fixed with the current capabilities and features. @Tom Reem Kindly help, ASAP!
Hello! I am trying to use MCP server. I have got account witch proffesional plan on, newest version of Figma Destkop App (just reinstalled). When I try to start MCP server, I get red error: Can you help me please?
Hey! We are an INGO. We are looking forward to use use FIGMA in our upcoming projects. Can you please let me know if you have some discounted plans available for non profit organization? We would like subscribe for it. Thanks and Regards, Vijetha Mehta Product Manager, FieldsData
I am working with Figma for about 3 years and it is a wonderful software. Speed used to be awesome in the beginning. It changed after a while and now it is really a pain to open files, select frames and resize areas. It starts blocking my work. You read always “Empty the cache...” I did but no change. Please dear Figma team realize that there is a problem that needs your attention.
Hi, I created an interactive component that worked fine until one week ago (more or less). Now, when you hover on it the font changes and shows the message “Some missing fonts were replaced”
Hi, I’m trying to change e-mail that I am using for my figma account to the one from which I am writing but even after following the steps several times I keep getting below error and I am stuck with the old e-mail. Any support anyone? :(
Hello,When using the text tool, I'm unable to get text to manually hard return, or skip to next line when hitting enter. I have text with hard returns in document that I previously created on both Windows and Apple computers, but even those blocks of text will not hard return when the cursor is placed inside when using browser on fairly new Samsung Android tablet. Text returns work in other applications (google docs, notes, web forms, etc) Any suggestions?
In Dev mode if I want to just copy one or 2 lines from the style code block, it’ll paste it out as just a unicode instead. I’ll have to use only the copy button to copy all the code for it to work - which is overkill and a waste of time for what I need. This never use to be the way.
I’m trying to create a button, using my variables for correct coloring on themes. My actionable icon hover is connected and showing up correctly However, when I place this component in the button lock up - the surface/default changes from light to dark - even though no variables modes are set on the component/frame/or section. No variable modes applied (on component/frame/or section) And I know this is true since my actionable icons component lives within the same frame & section and is appearing as wanted How do I fix this? Please help
Find answers, learn more.
