Scale tool (K) bug - Anchor points turn grey and tool stops working
- 3 replies
- 383 views
Hey everyone,
I've been experiencing a persistent bug with the Scale tool (K) that's significantly interrupting my workflow.
Here's how it normally works and where the bug occurs:
Expected Behavior (Working as intended):
I press K to activate the Scale tool.
I scale the object.
I press Escape or Enter to apply the changes.
The tool works perfectly.
The Bug:
I scale the object.
Instead of pressing Enter/Escape, I click anywhere else on the canvas to deselect the object or shift focus. (This is where I suspect the tool enters a 'limbo' state; the panel reverts to normal, but the scale tool isn't properly closed, even though this behavior worked fine previously.)
When I then try to use the Scale tool (K) again on any object, the anchor point squares (the small boxes that control the scaling origin) turn grey, and the tool completely stops functioning. Clicking on anything doesn't re-enable it.
Workaround: The only way to fix this is to reload the Figma tab.
This bug is quite disruptive, as it forces a reload often.
Thanks for your help!
OS/specs
Figma Desktop App, version 125.5.6
Mac Book pro 2021 / MacOs 13.0 (22A380) / Apple M1 Pro
