não tenho disponível esse novo recurso de draw na minha barra de ferramentas, como faço?
So I’ve built a site using variable sets as usual with intention to have both Light and Dark modes available only to find out there is no “Set variable mode” interaction in the menu for Figma Sites. Am I missing something? And if the feature is just gone, is there a workaround you can recommend to change the variable sets from the website UI?
Hi everyone, I’m running into a strange issue while working on a small side project — a mobile UI concept for a game prototype called TABS Pocket Edition APK. I exported some UI assets (buttons, icons, and a few layout elements) from the original build to test how they’d look in a Figma prototype.However, after importing them into Figma, the colors and shadows appear slightly different — almost “washed out” — compared to the original assets. Here’s the sample package I’m using (safe to open, just contains the demo assets so you can see what I mean): https://modhello.com/tabs-pocket-edition What I’ve tried so far: Checked color profiles in the exported PNGs. Imported via both drag-and-drop and “Place Image” option. Disabled Figma’s color management in preferences. Has anyone experienced this kind of color/contrast shift when bringing in mobile game UI assets?Any advice on settings or export formats that preserve the exact colors would be super helpful. Thanks in advance!
I’ve tried to create a webapp with Make to feature user authentication, progress tracking, and email delivery of PDF packages. This requires Supabase for user management, data storage, and API integration with Resend for email delivery. Now, whenever I get the Connect to Supabase window with the Setup your account prompt and the Connect button. I click Connect, get redirected to status=succedded page with Successfully authenticated response, but when I get back to Figma Make, the window still just shows Connect, not the other options after connecting. Is there anyway to clear and start over with the supabase integration? or am I missing something very obvious? thank you for any help!
Hey everyone, Just discovered that Figma Make has officially released its Supabase integration—but here’s the interesting part: I’ve already been using Supabase with Figma Make before this integration even existed. The new integration is cool, but it mainly supports simple key-value pair setups. If you’re building anything more complex or relational, it quickly hits limitations. So here’s a method I’ve been using that still works perfectly—especially for advanced database structures: ✅ My Method to Set Up Complex Supabase Databases in Figma Make 1. Structure your app in Figma Make. Make sure your app's UI and components are well-organized. 2. Ask Figma Make AI for the database schema: Prompt: “Generate a Supabase schema that can be run in the SQL Editor to create tables that support my current app.” 3. It will generate a .sql file inside your app's code structure. 4. Copy that SQL schema and paste it into the SQL Editor of your Supabase project. 5. Run it. If there are any errors, simp
The web under development has become too slow in AI development. I think there are too many codes that have died of uselessness by adding and subtracting many functions. The user page has not slowed down much, but only AI development has slowed down, so is there a good way to improve this?
I'm building a web with a make AI model. I'm a beginner, so I'm using more than 200 versions due to prompt abuse, which seems to be why the web development page is slowing down. Is there a way to delete the version?
I am using the figma mcp’s get_image config for the image is as follows when i click on a node and select copy as png the image is clear crisp but when i use mcp to export the image its blurry and not so great
Does anyone know of a way to do promise-based messaging between the plugin and the UI? (@Gleb 🙂) Using the globals: parent.postMessage(...) → figma.ui.onmessage → figma.ui.postMessage(...) → window.onmessage can lead to spaghetti code… promises would be so much cleaner. Really only the UI → Plugin direction would be fine, e.g.: someCoolMessaging.post(type: 'get-some-data', payload: { id: 5 }).then(data => { console.log('got some data', data) }) .catch((error) => { console.log('error getting data from plugin') })
In Figma Make, how do you delete extra or empty files from the code tree? I can’t delete them or prompt the AI to delete them successfully. I’d like to make sure they do not confuse future prompts.
Hello everyone, I’m looking for some guidance on hiring a professional to help manage my online presence. Recently, some outdated or misleading information has started affecting my personal brand and business reputation. I’ve been advised to work with a Reputation Management consultant, but I’m not sure what to look for or how to evaluate one. Has anyone here worked with a consultant like this before? What should I expect in terms of cost, strategy, and results? Any recommendations or red flags to watch out for would be greatly appreciated.
I've been having a very weird issue in Figma recently. When trying to move objects in a Frame it blocks me for some reason, but it does let me move around a couple of objects on the top. Objects outside of this frame are able to be moved freely. And if I move the order in the layers section then it works (the frame has auto layout on).Does anyone know why this is happening and how to resolve this issue? https://imgur.com/a/PKxFTs2
Find answers, learn more.
