Queens Digital Agency
Jun 28, 2025 10:37 AM UTC
Background colours change on pptx
Hi there
I designed - actually i have slides that i made by using html to design importer. On figmage they are fine but when i download the pptx file - the background colours are all gone.
Kindly assist
Thanks
Jun 30, 2025 2:56 AM UTC
Hi ​@Queens Digital Agency,
I understand you're having trouble with background colors disappearing when you export your slides to PPTX.
Thanks for sharing the file. Just wanted to check if you're using gradient fills for the backgrounds?
If you are using gradients, the issues you're encountering might be related to current limitations with the PPTX export feature. You can find more details about these known limitations here:
If the issue isn't related to the limitations mentioned above, I'd suggest filing a bug report so we can investigate this further for you. You can refer to this guide when submitting your report:
Thanks for your help!
