The fonts in my figma file have changed automatically to a random font, when I tap on them they change back to the correct fonts but I need to manually click on each text field.
It seem that the variable browser inside Figma is getting the wrong value when you hover over an alias. It then gets the value from the first mode, instead of the value for the mode it is referenced in. This error seem to also propagate to the Plugin API for reading the variable values. This file demostrates the issue explained below. “Header padding” in the Medium mode seem to have the value 48 when you hover over it. Which is the value from the Large mode, not the 24 from the Medium mode. However when you apply the value in the design it works as expected and the value is actually 24, when the mode is set to Medium. Even more, if you go to the variable browser and unlink the value if also gets the value 24. My main issue is not the hover in the variable browser, but the fact that also the Plugin API is getting the wrong values.
I tried Figma MCP when it was presented - and everything worked perfectly, but previous week it stopped responding for most of my models, but for some it randomly gives something. Actually it doesn’t work for me as it worked previously. Does anyone knows what’s the issue and how to resolve?
Hello, I have noticed:when switching component variants inside grid cell - something begin to break inside properties panel (there were cleaned properties before for sure I cleaned them perfectly! - and some Property5 & 6 appeared after dragging cell variants). I think this is a bug. PS I can’t upload bug video here to show you (I don’t have google drive / loom / dropbox - btw why so uncomfy to add a video?)
I recently cancelled the Professional plan, as we currently no longer require its services. We need to download the latest invoice, but it appears that the billing section is no longer accessible from the free plan. Could you please advise on how we can retrieve it? Thank you in advance for your assistance.Kind regards,Stefano Renò
I’m taking a Figma class and in the video there are 2 things regarding ‘horizontal padding’ that are inconsistent with how my design is acting compared to the instructors. In the top left I can’t select the ‘Distribute horizontal spacing’ When I add horizontal padding to a group of components, it shifts them to the right, while and doesn’t add the correct padding on the left and right side of the cards which should push them 24 pixels inside of the parent frame.
Dear Figma Team, I hope this message finds you well. I am writing to kindly request access to Figma First Draft. As a user currently on the free plan, I am very interested in exploring this feature to enhance my design workflow and bring more creativity and efficiency to my projects. I believe First Draft could be a valuable tool in helping me generate ideas and iterate faster, especially as I work on solo and collaborative design tasks. I’m eager to test its capabilities and provide feedback that could contribute to its development. Thank you for considering my request. I would greatly appreciate the opportunity to try out First Draft and see how it can support my design process. Best regards,Mario
This past week there is an issue that has been coming up a lot lately with transparencies in exported PNG file from Figma. In the years using Figma, I have never experienced this issue.I went a few rounds with this issue even creating modules from scratch (framing shapes, masking shapes and so on) and was still having small fine transparency issues at the bottom and sometimes the top of my exported PNGs. Alll frames in the Figma platform had no gaps in the frame and the shapes what so ever. Anything I did when exporting seem ineffective and transparency issues were still present. I showed another Figma designer this issue and did create some modules step by step in collaboration and we both could not figure out what was causing this issue. The only conclusion we could draw is there was an issue with Figma itself. Has anyone else been experiencing this issue also?
I’d love to suggest a small but potentially powerful feature:a local clipboard panel inside the canvas. Think of it as a lightweight, always-visible spot where I can quickly drag elements I create during a session and reuse them throughout the file — like a mini asset shelf, but temporary and personal. 🎯 Use case: While working on complex screens, I often create utility elements (buttons, arrows, highlights, etc.) that I need to reuse across multiple frames. Right now I either copy-paste from frame to frame or scroll back and forth.With a built-in clipboard panel, I could drop those elements in one place and simply drag them out when needed. That would seriously reduce navigation time and context switching — especially on large-scale design systems or messy exploratory files. Attaching a quick visual mockup of the idea for clarity.Would love to hear what you think!
Hey Figma Heads! I’ve noticed that some of my icons have holes in the circles where they’re not supposed to (e.g., in images). Does anyone know how to fix this issue while keeping everything in a single vector and maintaining a consistent stroke size? It seems like the problem might be caused by the stroke breaking into negative space when overlapping itself. The last image shows what it’s supposed to look like. Any help would be greatly appreciated! How the icon is suppose to look like
Find answers, learn more.
