I’m still getting to grips with Figma. I’ve just noticed that there is now Figma Sites. If I purchase a paid plan, does this give me access to Figma Design as well, or just Sites?
I want to copy an image from one instance to another, but it’s not working anymore. When I click in the image area, the “copy” function doesn’t seem to work anymore.
Hello! I created a team project on an education plan linked to my school email. Since I just graduated, I will lose access to it soon but I have important projects on there that I don't want to loose. I already changed "ownership" of the project to my private email. But is that enough? Or do I need to get a paid plan to somehow transfer the files? I don’t quite understand where figma stores these files. Thank you in advance!
Hello, Is is possible to use command-line with arguments in the Desktop app (command prompts)? And optionally is it possible to create commands to use when using the app? Just to show an exemple to explain what I have in mind using from a Windows bat file( I know that the name of the Desktop app path is incorrect here): figamapp.exe -open myFile.fig
Since yesterday my figma runs really slow and also shows storage issues. even if the file did not change now my storage space is suddenly full. Working like this is not even possible as i have to wait for certian things up to a minute and it is also pixalated.
ok
This has been mentioned here: Hide layer using variables - #5 by Andreas_Braendhaugen1 Invert boolean variable for layer display - #14 by Desislava_Slavkova Inverted Boolean Property - #2 by drewcovi_usb but those topics are all closed. I am looking for the availability to HIDE a layer when a Boolean variable is TRUE and SHOW it when it is FALSE. So, the inverse of the default/current behavior. I want to do this without using components. Use case: When a variable is true, show one frame. When that same variable is false, show a different frame. I can get basically this by using two different variables: but it would be more convenient to be able to do it with just one. Just give me a Boolean toggle when the variable is used to say if the variable should be inverted or not.
I encountered a very headheadache problem today. Without any limit prompt, my figma make kept telling me "Try again with fewer inputs". I tried different inputs but couldn't ask questions. If this conversation is too long to ask questions in this make, is there a way to migrate my code to a new make to start a new conversation?
As an admin of my org, there should be a way to transfer ownership of projects and workspaces from associates that have left my company to someone else.
Enhancing variables to have extra logic in place so that variables can be partially based off other variables e.g. Number new_variable = “{other_number_variable} + 4” String new_variable = “{other_text_variable} New Text” Colour new_variable = “{other_color_variable}, opacity 4” Boolean new_variable = “not {other_boolean_variable}”
Hey! I’m relatively new to Figma and I need a bit of help.I want to create a size selection button for my clothing e-shop prototype. Each size selection should be highlighted with a fill independently when selected—meaning to say if I have size S,M,L,XL, I can only choose one option. Additionally, I also want a ‘unavailable’ option where the button cannot be interacted with. Thank you so much! 😃
Hi all. I’m new to Figma and currently working on a project where I’m generating cards using text pulled from a Google Sheet via a plugin like Google Sheets Sync. The sync is working fine. Each card is receiving the correct text from the sheet. However, I’d like to go a step further and apply specific font colors to certain words or patterns within the text. Here is the data in sheets: Here’s a screenshot of the cards in Figma: The 2 cards in the frame are populating with the text correctly. However I would like the font to have certain colors based on certain keywords. For example, In Line 1: “Some” and “line” should be red, everything else in line 1 should be white. In Line 2: “Some” should be red, anything text in bracket should be orange, etc. My Questions: Is this type of partial, inline text formatting (color changes) possible when using data from Google Sheets? Are there any beginner-friendly tips or best practices to achieve this? I’m hoping to avoid having to manually change t
Find answers, learn more.
