How do I conditionally format text field being populated using Google Sheet plugin?
  • July 15, 2025
  • 10 views
LOkwu
Hi all. I’m new to Figma and currently working on a project where I’m generating cards using text pulled from a Google Sheet via a plugin like Google Sheets Sync.
The sync is working fine. Each card is receiving the correct text from the sheet. However, I’d like to go a step further and apply specific font colors to certain words or patterns within the text.
Here is the data in sheets:
Here’s a screenshot of the cards in Figma:
The 2 cards in the frame are populating with the text correctly. However I would like the font to have certain colors based on certain keywords. For example,
  • In Line 1: “Some” and “line” should be red, everything else in line 1 should be white.
  • In Line 2: “Some” should be red, anything text in bracket should be orange, etc.
My Questions:
  • Is this type of partial, inline text formatting (color changes) possible when using data from Google Sheets?
  • Are there any beginner-friendly tips or best practices to achieve this?
I’m hoping to avoid having to manually change the colors of individual words in each card.
Thanks in advance!
Thanks.
Ellwood
  • Active Member
  • 21 replies
  • July 15, 2025
Hi ​@LOkwu ,
I’ve been using the google sheets plugin for a while and to the best of my knowledge, there’s no way to conditionally format portions of text within a single imported data field.
You could cut up the string into different data cells to target a specific ordering (ie first word) depending how you cut up the string (could be a lot of manual work to manipulate the data especially if using a large data set), and create an autolayout to bring the sentence together. This way you could style words given a specific order in the sentence, but still, this doesn’t allow you to essentially ‘search’ for specific words or patterns of words to style differently.
Hope that helps.
