I faced this problem on and not off but couldn’t really find any patterns. Sometimes, figma make is hallucinating with my prompts and giving weird screens (replacing existing screens) and giving wild outputs. After some time or the next day, the problem is getting fixed. For sure, the problem is not with the prompt, the problem starts with the way it is reasoning it. If this can be fixed, it will be really good because the flow is getting cut quite often.
Hi everyone, I used to copy an image (Ctrl+C from browser or local folder) and then paste it (Ctrl+V) directly into an image component in Figma - like for cards or avatar images - and it would automatically replace the image. But recently, this no longer works. When I try pasting, nothing happens. Now Figma only shows options like “Upload from computer” or “Make an image” (screenshot attached). I’m wondering: is this a recent change or bug in Figma?Is there still a way to paste an image directly into a component without having to upload it manually? Thanks in advance!
The new glass effect works very nicely in the editor viewport, however when you present your design in present mode, it looks very pixelated and some random diagonal black lines appear when you present in full-screen Is it just me or you as well?
I’ve created a project in Figma, and it’s working fine—I can also view the React code. However, when I tried to export and run it on my local system, I noticed that a required file, package.json, is missing.Could you please guide me on how to properly run this project locally? I already have the necessary technologies installed on my system.
I am trying to do what seems like a pretty easy task: merging changes in a branch into the main file. Here are my steps: From the branch, I click the dropdown arrow next to the branch name. Select the option to merge I resolve all conflicts Complete the merge. Expected result: The changes from the branch should appear in the main file. Actual result: They don’t. Nothing happens. Main stays the same, branch stays the same. On top of that, the Figma labeling is confusing. It’s either incorrect/copy errors that are confusing, or I am legitimately not doing this correctly. For example, then the merge modal is up, the title of the modal reads “update from main file.” But that’s not what I’m doing, I selected to do the opposite AND the UI reflects I am doing the opposite: I am “merging branch” not “updating from the main file.” This whole feature feels half baked, and in the meantime, I’m going to abandon it by simple copying all my changes from the branch into the main file, then archive th
Hi, I have created a dropdown component with variables where i select option and it update the text in field. But the problem is that when i am using this component in other file and the option text changed then it is not changing the option text when i am opening the dropdown it is showing the basic value that was set in base component open state.In component i set local variable for label (Variable: SelectOption)For each option in dropdown options i set variable option1, option2 and so on Now in other file i am using that component and create some local variables for select option and options in list. I detach the variable and assign new local variables. But when i am checking it in “Present” mode it is still showing me Option 1 and Option 2 in list Really need help here that how can i update the variables in other file to use the same functionality
Since the last update, it’s impossible to copy and paste the image fill, into another component. I’m working with Auto Layout and I used to be able to select the fill > copy this > open another component > select the fill > paste. This doesn’t work anymore. It’s a feature I use all the time. Does anybody else experience this?
i have been using figma make for my recent project, i have used it around 2 days . but now when i send a prompt it throws an error “ something went wrong try agin after some time” i have tried duplicating the file and waited for more time still the issue persist note: ( i am facing this issue after 2 days of usage it mean i have made around 300 prompts and more)
I spend a lot of time undoing the automatic auto layout adjustments that Figma applies in order to maintain the existing layout structure. This is frustrating because I understand how all the resizing parameters work, and I only change the ones I want to change. But in an attempt to help me and retain the current layout, the UI changes parameters that were previously the way I wanted them. So while auto layout still saves me time, it also wastes my time by putting me in a position where I have to go through, layer by layer, undoing the auto-adjustments. (Usually changing a layer’s width or height from “fixed” back to “fill” or “hug”.) I understand some users may actually like this, and it’s hard to please everyone. I would be more than grateful for an option that allows me to disable this automatic behavior.
Unable to change Community Profile name to “Wai Technologies” and have to upload profile picture, not able to do it. Please assist on the same.
Hello community, I am looking for any information on how working with branches and merging branches has been for you guys. I am currently working with a file that should serve as a single source of truth for other files. It is a design system file with variables and a hierarchy of namings for the variables. We are considering restructuring some of the variable groups and how the group namings are set up. We might group variables into a functionality structure where components that are usually used for input & controls are grouped together, then components that are for content & display are in another group, then components that are usually for navigation are in another group, feedback & status group, layout & structure group, and then maybe an overlays group. We might also regroup typography variables like fontsize, weight, and family into a nested group structure. Some of our variables have generic semantic names and then some have a more specific component level name. We have set up
Hey there! 👋🏼 For over a week now, it seems like empty rows from the spreadsheet are being included when assigning properties to template layers. As a result, I’m getting over 1,000 assets created with no content (since the rows have no information). That wasn’t the case a few weeks ago, when I created and tested the templates before sharing them with the rest of the team. I assume this is a bug, but I wanted to ask if you are working on solving this issue? Warm regards, Aleksandra
Find answers, learn more.
