Не работает Figma и не можем зарегистрировать новый аккаунт, не знаю может интернет медленный, но Captha не загружается и когда вхожу в приложение Figma оно открывается и там чистое поле и сверху домик и всё, что делать подскажите пожалуйста.
Hi Figma team, It would be great to add a sitemaps generation in the settings of Figma Sites.Which auto generates when adding new pages and could be edited as well in XML.That would improve SEO and custom configs.You could potentially add an AI feature for this to auto optimize your sites Thanks
If I use CMD+B shortcut on any Frame/Section, it bolds everything inside it, but can’t undo that operation using CMD+Z
After I created a website in Figma Make, I downloaded the code into a zip file. However, all of the images missed. I looked into the code and find the images are in the following format: “figma:asset/<id>.png";However, the assets folder is not in the downloaded zip. Where can I find the assets? Is there a possible solution?
Variables are missing for Effects like drop shadow, inner shadow, blur, and background blur. They should be used for the number fields and colors, so we can have dynamically applying themes and sizes for these effects.
I created a component 1 (main component), and copy paste it as component 2. I want to modify the component 2 a bit, for example the layout of textbox. I’ll have to detach component 2 from component 1 (main component). Can I re-attach component 2 to component 1 (main component) after I detach it?Or is there any other way to modify component layout?
Since the last update, it’s impossible to copy and paste the image fill, into another component. I’m working with Auto Layout and I used to be able to select the fill > copy this > open another component > select the fill > paste. This doesn’t work anymore. It’s a feature I use all the time. Does anybody else experience this?
Just this week I’m having issues copy/pasting prototype noodles. It only works sometimes, but most of time it copy/pastes the entire frame and ignores the prototype noodle completely. Please help.
Hi Figma team, I’ve encountered an issue when trying to apply a linear gradient to a single word inside a text layer. When I highlight just one word and apply a gradient (via the fill panel), the gradient technically applies, but no gradient handles appear on the canvas. This makes it impossible to adjust the direction, angle, or position of the gradient for that specific word. Steps to reproduce: Create a text layer with multiple words. Highlight just one word. Apply a linear gradient via the Fill settings. Try to adjust the gradient. Expected behavior: Gradient handles (start and end points) should appear, just like they do when applying a gradient to an entire shape or full text layer. I should be able to control the direction of the gradient within the selected word. Actual behavior: No gradient nodes/handles appear when the gradient is applied to only a portion of the text. The gradient applies, but I have no way to control it visually. Please let me know if this is a known limita
I just wanna ask if where can I access the variable. It says here Draw but I never converted my files to FigJam it just automatically turned like this.
i want to access ui 3 figma ai ..plase roll out for me...i am very old figma user from india
Find answers, learn more.
