Phu2
Jul 16, 2025 3:59 AM UTC
Keyboard shortcut for Select matching layers doesn't work
Option + Command + A is the only shortcut that doesn’t work on my Macbook Pro 2024 (Sequoia). Clicking on the button on the right-hand side panel works.
All other shortcuts involved the Option + Command + [any key] works though.
Phu2
Phu2Solution
Jul 30, 2025 7:51 AM UTC
I found the app that was using the same shortcut for screen capture… The problem is solved. Thank you for your attention to this!
Jul 17, 2025 2:03 PM UTC
Hi there, thanks for flagging this! This sounds odd, especially since other Option + Command + [key] shortcuts are working as expected.
Does this happen in the browser, the desktop app, or both? If you haven’t already, try force-quitting and restarting Figma to see if that helps.
It’s possible this could be related to a system-level shortcut conflict in macOS Sequoia but it would be great to investigate it further. Since the button in the right-hand panel still works, at least you're not blocked but I’d recommend submitting a bug report so our team can investigate further.
If possible, include your macOS version and a short screen recording of the issue that really helps us dig in. Thanks again for reporting this!
Phu2
Phu2AuthorSolution
Jul 30, 2025 12:34 PM UTC
Great! Thanks for letting me know. I’ve gone ahead and marked as solved the topic, thank you 🙂
