I’m encountering some issues with Figma; regardless of whether the file has many pages or few, the operations are very laggy. I’ve tried changing my network and using a VPN, but neither has made a significant difference. What should I try now?
I recently canceled my Pro subscription, but I noticed that a $20 charge is still currently processing on my card. I would like to request that this transaction be canceled immediately before the charge is completed, as I no longer wish to use the Pro plan. Please confirm that the charge will not go through and that my subscription is fully canceled. Thank you for your help
Hi, how can i add my catalogue pdf to figma sites.. , as you know figma sites connects custom domains via dns servers but there is no ftp access, so where can we load pdf files to show it in our web page ?..
The get_code just gets stuck on this even if I select the smallest of frames. I am using a local proxy setting so is it because of that and if yes, how can I configure it figma to detect the proxy and get this working?
Hi everyone, I'm currently taking over a large Figma project from another company, and I’ve run into a major issue with component linking. I’ll try to explain as clearly as possible: The previous team provided me with several Figma files: A working file A library file (which includes the UI kit, components, ...) A color styles file An icon file I uploaded all of these files into my company’s Figma workspace. Then I published the three system files (library, color styles, icons) so they act as design system libraries. After that, I opened the working file and added all three published libraries to it. The problem is: none of the components in the working file are connected to the published library. They appear as external components but not linked. Manually linking works correclty, but this project has over 100+ pages, so manually relinking everything isn’t realistic. My questions are: Am I missing a key step in the import or publishing process? Is there a way to get the working file to
Favourite fonts will be shown on top of the list, while the rest of it will be shown below the favourite list. We should also be able to remove and add while viewing the fonts on the font list.
When sharing a Figma file with view-only access, the code panel is no longer visible to viewers. Additionally, I am facing a 10–20 second lag while working, which is slowing down the workflow. Both issues are making coordination much harder than before. @Gayani_S @Tom Reem – requesting your attention on this.
Download code button I spotted the "Download Code" option in the upper right corner of the editor, but I noticed that there is no "package.json" file. Is there any documentation or a way to run these projects locally using my own IDE?
I have a a few project with in my account. There is one that I accidentally set to education and . How can i take my account status out of education and place it back into a free starter account?
Is there a way I can convert my Figma Make design to Figma design?
I’m getting the following error- We can't open this file because we're having trouble with WebGL. Please try restarting the desktop app. If this problem persists, your graphics card or driver may not be supported. This happened after updating Figma. It works perfectly on different browsers but the desktop app isn’t working. Are there any fixes for this?
I’m sending a get_code request to the Figma MCP server via Cursor AI.Here is the request body I’m using: { "nodeId": "XXXX:XXXX", "clientLanguages": "kotlin", "clientFrameworks": "android,compose", "clientName": "cursor" } However, the response I receive is in JSX (JavaScript XML) format with Tailwind CSS classes, not Kotlin.I would expect either Kotlin code (Jetpack Compose) or at least a clean JSON representation of the selected frame. Question: How can I retrieve Kotlin code or a raw JSON object for the selected frame?
Find answers, learn more.
