Add the ability to select which properties to publish of a component and of a nested component. One use case for this is State in many components such as Button. State has Default, Hover, and Pressed. These states don’t need to be published, they are purely used for prototypes. I don’t want to clutter the properties list for consuming designers. Disabled and Error are created as Variants with “true” and “false” values. There’s no need to publish State property. Original idea here requested by XavierV
My Make workspace has crashed. I asked Claude Sonnet 4 to create a more tech-style design for my page, and I believe it added too many elements when generating the landing page. Now everything is stuck, the page won’t load, Make is completely unresponsive, and when I try to revert to a previous version, nothing happens. This is urgent. Please help me fix this or show me how to solve it myself. Just to clarify, this is not an issue with my computer. I’m using a high-end setup with a 4060 Ti GPU, and everything else works perfectly, including programming other pages. Thank you in advance.
I’m trying to roll back a Figma Make file to a previous version, but it’s not allowing me to. I just get this message without any further context or explanation. No matter how far I rollback, same message. Has anyone else encountered this? Any idea how to resolve it?
This makes it easier to use components in designs for different screen sizes. And then you don’t have to calculate every time what 40% or 60% of the width is. This also makes it easier to design scalable applications that grow with the width of the screen.
As a designer using a design system and searching or swapping a component instancr, often a term you search pulls up other components not in line with what you want because of a similarity in name. The most common culprit are icons. It would be great to do a quick negative filter like in VSCode with find and replace when looking for components to swap or insert to negate a group of components. This could also be a quick hack to cut out other active design systems from the keyboard.
Would be nice to limit this permission to developers only, while still allowing other roles to view files. It is about time Figma improves the role and permissions management. We need dev roles or more granular permission settings.
We’re working on a larger Component library that includes non-published components (components with the prefix _ or .) as base components in order to simplify large, complex components. We intended – in some specific cases – to offer regular components as templates, that a designer would then have to detach and work with a bunch of base components to build the desired design. What we have come to realize with this approach, however, is that these non-published components don’t receive updates from the library when they are updated in the main library. Is this intended behaviour? We basically have the option to simply publish these base components as regular components, but that of course would mean cluttering up the assets overview with a bunch of modular components.
Hi all, I am trying to create localised assets for my company and using Figma Buzz and the Bulk Create feature. I paste in the template I am working with into Figma Buzz, upload the xlsx file with the format as attached but when connecting the items and clicking “Create assets” it’s creating the assets but it’s just duplicating them. It’s not replacing the text as per the spreadsheet. What am I doing wrong? Or is this a bug?
Hi, After the update, I can no longer copy individual CSS style properties. Now it’s only possible to use the copy button, but in that case it copies all the styles.
We host the web page in figma.site servers , but i want to host my own html files in my server ? how can i get these files..
I faced this problem on and not off but couldn’t really find any patterns. Sometimes, figma make is hallucinating with my prompts and giving weird screens (replacing existing screens) and giving wild outputs. After some time or the next day, the problem is getting fixed. For sure, the problem is not with the prompt, the problem starts with the way it is reasoning it. If this can be fixed, it will be really good because the flow is getting cut quite often.
Hi community! I create a product card component with 2 variants. And when you hover over it, it will switch to the variant below. Both variants have an arrow, and the arrows have the same name as well as the same place in the hierarchy. They are connected with smart animate. I assume that when you hover over it, the arrow will not have any animation. However, when hovered over, the arrow will disappear and reappear. This is a clip of what it looks like when you hover over it. https://www.youtube.com/watch?v=SRa1mFr_61A How can I make the arrow just stay there? Is this behavior normal? Product Card Component Arrows in their respective hierarchy. The smart animate set up
I can no longer drag and drop variables. Just yesterday, I was able to rearrange colors, strings, and numbers. I’ve tested this across multiple files and accounts, but it no longer works in any case.
Over the past week, I've been having a problem exporting images. Some parts of the text or frames are shifted by a few pixels, as if they were cut out. At first, I thought the problem was with the font, but it turns out that this problem occurs with any font. I tried all methods, but the only solution I found was to shift the text and frames by a couple of pixels. Has anyone encountered a similar issue and knows how to resolve it? The text and frames have integer values without fractional parts and are tied to the pixel grid. Changing the file type to JPEG or PNG does not help either.
I am using Figma Slides and when adding Live Integration - Stamps the frame or text gets cuts in design mode and in present mode the whole Stamp frame/box gets cut on top and bottom. Design Mode - text in Stamp does not display in its fullness Present Mode - Stamp gets cut on top and bottom
Find answers, learn more.
