Using Figma under Windows. I have to review a figma design my designer created. There are many layers. I would like to view one layer. Is there any way I can Zoom to it after selecting it? It seems I have to hunt and zoom all around the screen to finally look at something. Figma doesn’t seem to work as a collaborative tool. Is there a save button for this topic/ post? I only see SEND. Send it where?
Hello, I used Figma site a lo recently and here are some feedback : The requirement to use a subdomain is quite restrictive. For example, if I'm forced to deploy my site on www.domain.com, I also need to redirect domain.com to www.domain.com to avoid users being blocked or unable to find the site when simply typing domain.com. This redirection then has to be set up manually on the server side, whether through a .htaccess file or an Nginx or Apache configuration. I have the technical skills to do this — it's my job — so it didn’t take me long. But it's far from accessible for someone who isn't a developer. In my case, the simplest solution would have been to host the site directly on domain.com. Dynamic components (e.g : carousel) which have breakpoint variants do not adapt responsively to the screen size. This cause major interface problems. The problem is not observed for static components. Buttons do not have focus states (interactions) which is highly problematic ATM for designing w
I would love to be able to create one prototype across the pages in a file that resembles an actual website. This would be ideal for bigger projects and would be easier to maintain as well. We can connect the component libraries across all the pages anyways. A way to connect the prototype would be great in my opinion and that will give Figma a big leg up on other platforms. What do you guys think?
I love that with the add-on I can better integrate figma designs to google workspace. It woul be awesome if the chip conversion would also work for google sheets currently its just a link, even if the add-on is installed. I would love to have it like in google docs:
I can't believe Figma is forcing this change on us. UI3 is, without a doubt, the most unfriendly design possible. It has made my workflow painfully slow and incredibly unproductive. What’s the harm in letting people CHOOSE which UI works best for them? I always thought switching to UI3 was a HUGE mistake, but I never felt the need to comment on it because UI2 was still an option. Now that you're FORCING this change, I have to speak up. This is NOT an upgrade. It’s a downgrade in usability, efficiency, and user experience. Figma was supposed to be about flexibility and user-centered design—so why ignore the feedback of those who actually use the platform every day? Give us back the choice. Let people stick to UI2 if they want. This forced migration is a slap in the face to long-time users who built their workflow around UI2.
We just wrapped the big announcements at Config , and we know there’s a lot to take in. This thread is your space to share reactions, ask questions, and let us know what you're excited about (or still curious about) with regard to Figma Make. Our team will be actively reading and sharing relevant takeaways with the product team. What we’d love to hear from you: What aspects are you most excited about — and why? Where do you still have questions or want more clarity? Anything that didn’t quite land for you yet? A few quick reminders: If you need help with a specific account or file issue, please get in touch with a specialist on the Support Team. A note on Community Guidelines: Posts that veer off-topic or become unproductive may be moderated to keep the focus on the product at hand. Keep feedback focused on Figma Make — this helps everyone follow along.
Hi everyone, I'm currently working on a UI mockup for a project related to Script Bot, and I'm running into some layout behavior that I can't quite figure out. I have a set of components (like navigation cards and action buttons) inside a container using Auto Layout. When I simulate state changes (like expanding or collapsing a section of the Script Bot APK UI), the entire frame seems to jump or flicker briefly especially when Smart Animate is applied. This doesn’t happen when I use “Instant” transitions combined with “Preserve scroll position,” but my goal is to achieve a smooth Smart Animate effect without breaking the scroll or causing jumpy behavior. Has anyone here run into something similar when prototyping APK-related interfaces? Any tips for keeping the scroll position stable when working with expanding elements and animation? : https://soundcloud.com/heyapks1/download-script-bot-apk-v300-offcial-free-for-android-version-2025 Thanks in advance!
Hello. I am trying to develop my android application. Now I am creating design for this. I don’t know how to do prototype between text input and opening user’s account of this app.For example,If I want to log in my account in this app,I should insert text in such strings as login and password and after this my account opens. How to do this? How to setup a right prototype in this case before coding?
We’re experiencing an issue with the #get_image tool in MCP. While it appears to retrieve the image successfully, the image does not render correctly in the actual implementation. This issue did not occur in the early stages of using MCP. Has there been any known issue or update related to this?
I’m the admin of my workspace with the Professional plan, and I have a collab seat. How can I share a draft with viewing rights with my client, without having to upgrade to a full seat? Whenever I click the share button, I see the dialogue that I’m about to upgrade to a full seat. I even already upgraded by accident, which was annoying as it incurred extra cost for something I don’t need). On the free plan I’m able to share drafts without problem. Why isn’t that possible on the Professional plan? Here’s a screenshot of the dialogue that I get whenever I click the share button. Would really appreciate some help with this, as it’s stated in the docs, that sharing designs with viewing rights should definitely be possible without upgrading the seat.
Hello Figma Team,I accidentally purchased 2 additional Dev seat accounts and was charged accordingly. I would like to request a refund for this accidental charge. Could you please let me know if a refund would be possible in this case? Thank you very much for your support.
Установила новый шрифт, Фигма его видит и применяет. Но когда выбираю токен с этим шрифтом, то Фигма выдаёт ошибку, что шрифт отсутствует. У остальных участников проекта все нормально работает
Find answers, learn more.
