The Annotation and Comment tools have their own cursors, but the Measure tool is the same as the default cursor (Move tool). I cannot count how many times I was confused and frustrated why I couldn’t move or edit an element, only to find out I was still using the Measure tool instead of the Move tool. Please give the Measure tool its own unique cursor!
Sometimes you need to be explicit when calling out a measurement where two elements are touching each other. The current dev mode measure tool does not allow you to explicitly measure a distance of 0. This is a required measurement for proper dev handoff and keeps us from using this feature.
Currently, in prototype the cursor appears to be either ‘pointer’ (for everything) or ‘hand’ (if a click interaction set up on an element). I would like to be able to change this to a text cursor, when hovering over an input field in my proto. Affordance is a very important part of UI so surprised theres no way to do this? Of course can hack it by adding an image of a cursor, but then you end up having that plus the actual cursor on screen & it makes things worse. Should be an easy feature to add and would be very much appreciated!
I am using theming. I am creating a theme for each one of my brands. One of my brands site background color is not a solid hex, however it is a linear gradient. I am not seeing any way to do that within the variables. Is that possible?
Hi everyone! Here is my setup: I have a main icon component that has all the sizes and the colors available. There is an instance property on the main icon component where designers can select which icon they want (basically a nested component) The nested icon component that is selected changes size and color depending on the settings of the main component Problem: We are adopting a new icon library I went into the icons that already exist and replaced the .svgs I created new icons Now all the instances of icon are not obeying the color property set in the parent and need to manually reset and reconfigured. This is hugely manual and annoying... is there something I can do to avoid all this effort, and why is this happening?
Make sure to like And subscribe and if you don't me and Preston are going to appear at your house tonight and we're going to stab you 12 times in the heart okay never mind we're not going to stab you 12 times in the heart we're going to give you a big hug
I use Figma in view only mode for work and for no reason now when I hover over a property variable the actual value of the variable doesn’t show anymore. I’ve only seen one other forum post talk about this from 9 months ago and the figma rep said it was fixed in an update. I restarted my laptop and installed figma desktop, but the problem persists. Does anyone know if there is any fix to this.
Hi, I have this issue in multiple Figma files. If I move frames with comments to another page, the comments still appear on the original page whenever the file is opened. The comments only disappear when navigating to the “moved” page and navigating back. This is really cumbersome because often the page in which frames with comments are moved to is a very large page which takes a long time to load. Also, engineers who are working off of the original page get confused about the comments that were moved and are not relevant to them.
Hello, can anybody help me with this issue? I have several .fig files, and whatever I try to import them, it’s “Unsupported file format”. I tried Import from “Create new” dialog, I drad and droped , the same result. Please, how to fix it? Thank you !
My Educational plan expires in 2 weeks, but I won't have money to actually buy one until 4 weeks, or even more. What I wanna know is what happens after it expires? Do all my files just sit there the way I left them until I can buy a plan, or is everything deleted or changed somehow? Will I lose any files that are over the file limit for the free plan? I won't be doing any changes to the file, but I just gotta make sure they stay there until I get the money. Thanks
Hi team, I’ve began using Figma Sites this week and having a consistent issue of my previews not loading at all, either on the desktop app or on Browser. This is persistent and ONLY affecting Sites - I am having no issues with previews in Make, etc. I have Reset and Restarted Figma, uninstalled and redownloaded the app too, to no avail. Is this a common issue or is there something specific going wrong here?
Find answers, learn more.
