I have a a few project with in my account. There is one that I accidentally set to education and . How can i take my account status out of education and place it back into a free starter account?
Slack integration stopped streaming comments to the channel
Hi, I’ve noticed an issue with changing the font family in the variables modal. The font does not update across all pages and components automatically. The font can be changed to the correct family when double clicking on a text box. Cheers, Sanny
Hi! I’m new to Figma Make and I just generated a screen using it. I’d like to continue editing that screen in my usual Figma workspace (not inside Make), but I’m not sure how to bring it into my main file. Is there a standard way to transfer or import Make-generated designs into regular Figma files? Thanks in advance for your help!
The new Figma update is just fine. I appreciate they tried to make the UI a bit more graphic, but in doing so - I feel like the program runs slower and the layers panel isn’t anymore intuitive, but now just clunky. One of the features I loved the most - manually adjusting spacing between elements, seems to have disappeared from the workspace entirely.
Example of Figma NOT exporting the gradient I set a gradient in the Fill and when I export the image the background will NOT contain the gradient fill? why is that?
I am trying to use the plugin ‘Magician’ in Figma, but when I do, it asks for an access code. However, when I click ‘Start Free Trial,’ it just loops back to Figma. What am I missing?
Good day, I ve started to use figma make today and created very good things until ı ve updated a code of a design and it gave some kind of error on the interface preview,the interface started to lag and finally when ı press the fix 10 problems ,smoothing thing out screen came into action as always but ıt goes into a eternal loop and doesnt fix or code somethnig.It is stucked. I would be glad if you help me with this problem.
i have been using figma make for my recent project, i have used it around 2 days . but now when i send a prompt it throws an error “ something went wrong try agin after some time” i have tried duplicating the file and waited for more time still the issue persist note: ( i am facing this issue after 2 days of usage it mean i have made around 300 prompts and more)
In grid features Canvas Stacking (Last to Top/First to top) is not working properly
If I use “ctrl + c” to copy a file from my computer, then select the layer in Figma I want to update and use “ctrl +v” to paste/replace it. The layer will inherit the name of the file on the desktop. So if it’s “IMG_ASD123” the Figma layer changes to be named this instead of what it was labeled in Figma. Is this a recent update? It never used to happen? It’s a bit frustrating as I used to name my layers “Asset (3:4)” or whatnot to indicate to dev what the ratio of the asset was but now I need to keep renaming it everytime I copy/paste a new assets onto the layer. Is there a way to disable this at all? Thanks in advance! 🙂
I’d love to see support for automatically renaming layers to match the filename of an image that's placed or replaced in a design. Right now, Figma uses the image filename as a layer name inconsistently—mostly during the initial placement, and not when replacing an image. This leads to extra manual work and inconsistent layer naming, especially when working with many assets. It would be incredibly helpful if Figma could auto-update the layer name to reflect the actual filename of the image fill—ideally both on placement and when replacing an image. Thanks for considering this improvement!
Find answers, learn more.
