We deals with editing of photoshoot, website,and app design
Recently, I needed to create some typography based graphics in my website project, I did not find any option to align the text to pen paths or shapes. It would be a must feature in Figma as the usecase prevails for many designers out here and in many projects. Yes, there are some extensions available but they are limited in functionality, do not provide necessary mechanisms. Please upvote this of you have came across to the same need.
Flow chart process mapping is good. Adding line jumps would make it great!
Hi Everyone I have recently paid for a Figma pro plan annual. I was able upload videos on the Figma file no problem, but now I suddenly can no longer upload any videos. It says I need to upgrade to a pro plan. But I am already on that plan. Has anyone experienced this? Anyone in Figma can help with this issue?
Hey, Figma Make has started doing this weird thing where in between during changes or updates to the code, it erases previously established major chunk of features with Hello World or something else in the App.tsx file. It just basically erases it and does not realize until mentioned otherwise in the new prompt. This has been happening very often now since my last 2 projects and few prompts. The above image is an example from one of my recent projects in Figma Make. I was building a huge movie tracker and during one of the changes, it just removed the major chunk of the app. When I mentioned it next in a prompt, this is what it replied as. Kindly fix this.
The client has shared a file with me and given me “can edit” rights, but I cant edit. I am getting this error “An Admin needs to update your seat so you can edit file”. Any ideas? Thanks
Using string variables as a “CMS” across multiple teams is great to achieve consistency in ux writing/labels etc. If only it was possible to use markup within the variables. Because sometimes i run into a textbox where I want to format part of the string as bold, italic, underline … the usual suspects. With the way string variables are currently set up I can not cover this case with them. Hence, it wold be great if some kind of markup support was added. Marry Christmas ;]
Hello :) I use the Figma starter version for personal designs. I’ve created a presentation to publish for the community. But I don’t see the “publish to community” button on that file. I am the owner of the file and did check the Figma guidelines and rules on publishing. Can someone help out here?
Hello. I was wondering if it is possible to have percentage values in variables, like setting percentage value for frame widths or shape sizes (etc.) that have variable modes applied to them? Percentage values could respond better to content that varies within a frame or frames within frames.
I use percentages in a project for the letter spacing. I can’t use variables to achieve this value. It always defaults to pixels.
This auto-layout frame is a child/inside a basic frame that I should be able to move things around in. How the heck do I turn this off when I hover over to click and drag. all I want to do is drag the group/autolayout over a bit manually and arrows in this small space are producing too large of a move. this comes up for me a ton and it’s insanely annoying. I can’t click and drag without it also changing the auto layout spacing. if I want to change that I will go to the tool sidebar and do it myself. I don’t need this pink stuff trying to do it for me just because i’ve hovered over it. Also, FYI - I couldn’t even screengrab it through the OS, because this literally happens on hover, so I snapped it with my phone - hence the bad photo, apologies.
Over the past week, I've been having a problem exporting images. Some parts of the text or frames are shifted by a few pixels, as if they were cut out. At first, I thought the problem was with the font, but it turns out that this problem occurs with any font. I tried all methods, but the only solution I found was to shift the text and frames by a couple of pixels. Has anyone encountered a similar issue and knows how to resolve it? The text and frames have integer values without fractional parts and are tied to the pixel grid. Changing the file type to JPEG or PNG does not help either.
Figma MCP server worked great with VS Code version 1.101.0 but in version 1.102.0, microsoft has moved MCP configuration to a new file named mcp.json instead of previous settings.json file. After doing all the configuration, the Figma MCP server tools do not show up under tools and the agent is unable to use Figma MCP server. Has anyone had any luck with this version? Can Figma team please validate and update documentation for Figma MCP Server setup?
Can you share a library from one organization to another without transferring it and making it public?
Previously, it was possible to copy the image used in the Fill property of one frame and paste it into another frame’s Fill. However, this functionality seems broken or removed in recent updates.This was especially useful for quickly reusing image fills across components. Currently, I have to export and re-import images, which significantly slows down workflow.Please restore or support this functionality again.
Find answers, learn more.
