JayHawq
Jul 15, 2025 2:43 PM UTC
VS Code Version 1.102.0 (latest) doesn't work with Figma MCP.
Figma MCP server worked great with VS Code version 1.101.0 but in version 1.102.0, microsoft has moved MCP configuration to a new file named mcp.json instead of previous settings.json file.  After doing all the configuration, the Figma MCP server tools do not show up under tools and the agent is unable to use Figma MCP server.
Has anyone had any luck with this version? Can Figma team please validate and update documentation for Figma MCP Server setup?
    Fabrício Sautner
    Jul 17, 2025 12:11 PM UTC
    Same problem here!
    Kevin Lin
    Jul 25, 2025 6:05 PM UTC
    Same here!
    varnika
    Jul 30, 2025 11:11 AM UTC
    Same here
    Pascal Vendt
    Aug 7, 2025 10:16 AM UTC
    Same here
    alexb2611
    Aug 7, 2025 11:36 AM UTC
    same here
    Fabrício Sautner
    Aug 20, 2025 8:26 PM UTC
    Solved with update VS Code Version!!
    danT
    Nov 17, 2025 5:44 PM UTC
    Issue seems back with VSCode 1.106.0  can no longer authenticate to Figma.
    2025-11-17 10:44:12.169 [info] Stopping server figma
    2025-11-17 10:44:12.190 [info] Starting server figma
    2025-11-17 10:44:12.190 [info] Connection state: Starting
    2025-11-17 10:44:12.190 [info] Starting server from LocalProcess extension host
    2025-11-17 10:44:12.199 [info] Connection state: Running
    2025-11-17 10:44:13.327 [info] Populated auth metadata
    2025-11-17 10:44:13.328 [warning] Error getting token from server metadata: Canceled: Canceled
    2025-11-17 10:44:13.331 [info] Connection state: Error 401 status sending message to https://mcp.figma.com/mcp: Unauthorized
    Paweł Kucmus
    Mar 19, 2026 5:10 PM UTC
    I’m getting the same error on VS Code Version: 1.111.0 (Universal) on a Mac:
    2026-03-19 18:02:57.941 [info] Connection state: Starting
    2026-03-19 18:02:57.944 [info] Starting server from LocalProcess extension host
    2026-03-19 18:02:57.944 [info] Connection state: Running
    2026-03-19 18:02:58.774 [info] Discovered resource metadata at https://mcp.figma.com/.well-known/oauth-protected-resource
    2026-03-19 18:02:58.775 [info] Using auth server metadata url: https://api.figma.com
    2026-03-19 18:02:59.294 [info] Discovered authorization server metadata at https://api.figma.com/.well-known/oauth-authorization-server
    2026-03-19 18:03:02.946 [info] Waiting for server to respond to `initialize` request...
    2026-03-19 18:03:07.946 [info] Waiting for server to respond to `initialize` request...
    2026-03-19 18:03:12.947 [info] Waiting for server to respond to `initialize` request...
    2026-03-19 18:03:17.945 [info] Waiting for server to respond to `initialize` request...
    2026-03-19 18:03:18.123 [warning] Error getting token from server metadata: Error: Failed to create authentication token
    2026-03-19 18:03:18.126 [info] Connection state: Error 401 status sending message to https://mcp.figma.com/mcp: Unauthorized
    Ángel López
    Apr 7, 2026 10:37 PM UTC
    I am having this issue today:
    2026-04-07 15:36:03.934 [info] Starting server figma
    2026-04-07 15:36:03.934 [info] Connection state: Starting
    2026-04-07 15:36:03.934 [info] Starting server from LocalProcess extension host
    2026-04-07 15:36:03.935 [info] Connection state: Running
    2026-04-07 15:36:04.175 [info] Discovered resource metadata at https://mcp.figma.com/.well-known/oauth-protected-resource
    2026-04-07 15:36:04.175 [info] Using auth server metadata url: https://api.figma.com
    2026-04-07 15:36:04.316 [info] Discovered authorization server metadata at https://api.figma.com/.well-known/oauth-authorization-server
    2026-04-07 15:36:04.318 [warning] Error getting token from server metadata: Canceled: Canceled
    2026-04-07 15:36:04.328 [info] Connection state: Error 401 status sending message to https://mcp.figma.com/mcp: Unauthorized
    It was working yesterday but it started failing today
