Hello, I’m running into a permissions issue since Figma restructured its plans and access controls. Our team works with a number of freelancers, and we need to grant them edit access to individual files—without giving them visibility into the rest of our files. Previously, we were able to share a single file with edit access, but now it seems the only option is to upgrade freelancers to a full design seat. Unfortunately, that also gives them Team-level access, which exposes all of our files. Is there a way to give freelancers edit access to just one file without granting broader permissions? This seems like a very basic, necessary feature. Thanks.
Issue Description Exported files are having their vertical text alignments changed to Middle. How to recreate Create a Figma Slide Create Text box 1. Set Text Alignment to Bottom. Create Text box 2. Set Text Alignment to Top. Export the slide. Both text fields in the resulting PPTX are now set to Text Align: Middle. Impact While you might not expect a pixel-perfect copy when you export from Figma Slides to PPTX, this issue will in many cases cause text boxes to overlap with each other. It also creates a lot of unnecessary manual work while impacting our workflow. Screenshots The screenshots below don’t really convey the full impact, sometimes you’ll end up with overlapping texts. But you get the idea. In Figma Slides: In Figma Slides In Powerpoint In Powerpoint
See a simple exemple below :
I wanted to delete and recreate a post that I accidentally created as a “Question” when I wanted to create is as a “Conversation”, but I realized I can’t delete the post because there is no delete button anywhere.
1. Describe the problem your experiencing and how your idea helps solve this I can open 1 plugin at time, the plugins are located only in plugin section. I don’t have any possibility to add plugin to UI (exp. sidebar). Also plugin windows can be opened only in Figma webview window. 2. Add as much context as possible (screenshots, Figma files, mockups, etc.) example of sidebar for plugins 3. Ask questions to bring the community into the conversation Does anyone else have same problems?
Hello, I am trying to get my prototype of a mobile app to have a fixed (not scrolling) header and footer. The elements don’t scroll when I select “fixed position” but the content behind them does not scroll all the way, leaving a bit of desired space on the page behind the fixed elements. Anyone know how I can get the page behind the fixed elements to scroll all the way? Anyone else running into this issue?
Currently Copy/Paste Properties doesn't seem to work at all. I have 2 simple rectangles with different fill colors and strokes. I copy one, then paste properties on the other. Nothing at all happens. This is in the standalone app on Windows.
Hello! For context I’m working on an application that syncs design system files from Figma and compiles them into CSS for multiple sites. I’m currently trying to implement some additional styles for links and trying to get the text decoration color / text decoration style / etc. from the Figma REST API, but it is not present in the styles or nodes. Is there currently a plan / way to get this data from the REST APIs or a timeline on this being available? Thanks!
A container set to horizontal auto layout with wrap, contains several instances of a component called ‘rectangle’.This rectangle component has 2 variants : A ‘default’ variant (a black square) and a ‘hidden’ variant (the same black square with a width and height set to 0px). Upon clicking the default square, the component changes to the ‘hidden’ variant.If you play the prototype, it’s great, upon clicking each ‘rectangle’, they disappear and the remaining instances wrap. But if I create a component from the container, the instances of this component don’t have the same behavior and the instance of ‘rectangle’ don’t wrap anymore. Am I missing something here ? Here’s the Link : Thanks for your help.The idea is to create a large field with many deletable chips inside.
Hey ,Its glad to hear that we have figma dev mode server , well done folks . but there is a problem most of the time i am facing i given a figma frame link it fetched the frame correctly but it generated completly a wrong screen which was not even 1% equavalent to what i gave .i used claude 3.7 model for the generation . Figma generated this screen (output) Figma frame input
I have published 3 sites now using Figma sites. They are all active and accessible...with one major problem… If the user types the name of the site without the www. in front (say they type site.com and hit enter)… there is no redirect automatically enabled and the user gets an “unsecure site” error message. I believe this should be covered automatically by Figma and the automatic SSL… but until such time, I’m wondering if there are DNS settings I need to add to cover this issue. Thanks,
I have a hard time finding the corresponding Chinese fonts in Figma. I think fonts in other languages have similar problems.Can we add the ability for the software to read font names? The font name displayed on the current text font selection interface The name of the font that should be displayed
The blue circle that appears every time there’s an library update keeps showing up, it tells me there’s updates from some years ago (which there’s not) and when I click it, it says “library updated” but the dot keeps appearing. This happen in all my layers and all my files.
Find answers, learn more.
