When creating prototype connections in Figma, it is sometimes difficult and time-consuming to find the right screen manually. Currently, I need to scroll and select the frame every time. It would be very user-friendly if a search bar is available at the top of the prototype connection panel. This will allow users to quickly search and select their desired frame or screen, making the prototyping process faster and more efficient. Why this feature is helpful: Saves time during prototyping Improves workflow efficiency Makes the experience more user-friendly, especially for large projects with many frames
As many users have reported and requested, please kindly add support for custom fonts in Figma Sites. I often use Google and Adobe Fonts with common fonts, but cannot see the correct results. This is an essential feature. Please kindly update this soon. 🙏🏼🌊
Hello! We have been having memory trouble with our Library file and have been working on making it more usable. In the process of doing this I did a test where I duplicated my library, and then proceeded to erase everything from it, every page, every style, every variable, every linked library. At the end the only thing left was 1 empty new page that I had created. After a refresh, the file was still showing 26% of memory usage and over 75k layers. I’m really unsure of what to make of that, over a half of the memory usage of my file is coming from… Nothing? Is this a known bug?
I have hacked my way to do this Drop Cap on Figma but I think it’ll be a good feature to consider under the typography property.
Currently, only Preview and Code edit modes are visible. Are additional editing modes accessible?
Is there a way to export an AI generated page into a regular figma design file and then edit from that?
I’d love to be able to copy and paste conditionals/variables statements, this would save time and errors. For example, I used a similar if statement multiple times and just needed to change 1 or 2 variables and numbers. But to do so, I had to re-write the statements every time.
I’m seeing “An error occurred while copying this file” when I attempt to duplicate a version from the history of a merged branch - see attached. Is this not doable?
We have users having issues with Design links disappearing after a refresh. It shows the design is there, but once they refresh or leave page and come back, they are gone. I have tried linking myself and have the same issue. Not sure if anyone has had experienced this before. We also contacted Atlassian support and they pointed us here.
When you copy and paste a object if there is no available room to the right then the new object should be pasted underneath instead of being pasted in the next available free space to the right where there aren’t any objects
Hello, I encounter a problem with a certain file.Some random square/rectangles/shadows appear on it but only for me (the other user on the file don’t see it), even when I’m connected on the owner acc.Also, the shadows change places when i zoom/dezoom I can’t find a solution or understand where its from
Hello! I have heard that you are about to update your bootcamp verification process starting September 23th. Starting September 23, self-verification of bootcamps will no longer be available, and an administrator will need to confirm the bootcamp and then grant access to students and instructors. I have the following questions: 1. If my company uses Figma as an online course rather than a bootcamp, do these updates apply to me? 2. Where can I find more detailed information, namely which organizations will be granted access, how the student and teacher confirmation process will work, and other details? Thank you in advance!
Find answers, learn more.
