The new Figma update is just fine. I appreciate they tried to make the UI a bit more graphic, but in doing so - I feel like the program runs slower and the layers panel isn’t anymore intuitive, but now just clunky. One of the features I loved the most - manually adjusting spacing between elements, seems to have disappeared from the workspace entirely.
Example of Figma NOT exporting the gradient I set a gradient in the Fill and when I export the image the background will NOT contain the gradient fill? why is that?
I am trying to use the plugin ‘Magician’ in Figma, but when I do, it asks for an access code. However, when I click ‘Start Free Trial,’ it just loops back to Figma. What am I missing?
Good day, I ve started to use figma make today and created very good things until ı ve updated a code of a design and it gave some kind of error on the interface preview,the interface started to lag and finally when ı press the fix 10 problems ,smoothing thing out screen came into action as always but ıt goes into a eternal loop and doesnt fix or code somethnig.It is stucked. I would be glad if you help me with this problem.
i have been using figma make for my recent project, i have used it around 2 days . but now when i send a prompt it throws an error “ something went wrong try agin after some time” i have tried duplicating the file and waited for more time still the issue persist note: ( i am facing this issue after 2 days of usage it mean i have made around 300 prompts and more)
In grid features Canvas Stacking (Last to Top/First to top) is not working properly
If I use “ctrl + c” to copy a file from my computer, then select the layer in Figma I want to update and use “ctrl +v” to paste/replace it. The layer will inherit the name of the file on the desktop. So if it’s “IMG_ASD123” the Figma layer changes to be named this instead of what it was labeled in Figma. Is this a recent update? It never used to happen? It’s a bit frustrating as I used to name my layers “Asset (3:4)” or whatnot to indicate to dev what the ratio of the asset was but now I need to keep renaming it everytime I copy/paste a new assets onto the layer. Is there a way to disable this at all? Thanks in advance! 🙂
I don’t use Figma all the time, I don’t want it to run anything on startup. It’s frustrating to manually remove Figma from Login Items, since it automatically adds itself there again. It would be nice to have at least an option to disable it in settings, or even better - remove that functionality at all, since it’s not user friendly. I want control over what and when the apps do at my workstation. P.S. If it’s needed for updates check - I’m more than okay to update on app start
If I change the icon in a button and then change the state of a button from default to hover, the icon color does NOT change. (works fine if you don’t change the icon)I’m using stroke icons, and the scope settings in the color variable is set up to handle stroke. Please let me know what I need to do to so the swapped icon will change color on override.Video: https://monosnap.com/file/RUUxOXXXdznZoemEG4Aow5wO4As8Vx
Hello, An admin-level dashboard for Figma AI analytics would be invaluable, giving us the visibility needed to: Measure Business Impact: Track adoption rates and usage to satisfy our internal reporting requirements. Drive Strategic Adoption: Identify which AI features are most popular and which teams are leading adoption. Support Our People: Celebrate team members who are regularly engaged with AI and identify users who may need more support to get started.
I’d love to see support for automatically renaming layers to match the filename of an image that's placed or replaced in a design. Right now, Figma uses the image filename as a layer name inconsistently—mostly during the initial placement, and not when replacing an image. This leads to extra manual work and inconsistent layer naming, especially when working with many assets. It would be incredibly helpful if Figma could auto-update the layer name to reflect the actual filename of the image fill—ideally both on placement and when replacing an image. Thanks for considering this improvement!
State change interactions are not working properly in component instances prototypes. Ex: button hover state is not activated when hovering; collapsed search bar breaks when changing to default (open) state. All interactions work as expected in the main component. They only break in the instances.
I simply drag and drop a component to inside of another component but didn’t work. I can’t add component as a child element to another component.
When i migrated my Google account on new e-mail I’m lost control under files. how can I return that?
We're currently experiencing an issue with Google authentication in our Figma Make + Supabase setup. When a user attempts to sign up using their Google account, the user is successfully created in Supabase, but the OAuth callback URL doesn't work as expected. As a result, the user isn't redirected to the authenticated part of the application. This breaks the login flow, effectively preventing access to the app despite the user being created in the Supabase auth table.
Find answers, learn more.
