Hello! I am trying to use MCP server. I have got account witch proffesional plan on, newest version of Figma Destkop App (just reinstalled). When I try to start MCP server, I get red error: Can you help me please?
Hey! We are an INGO. We are looking forward to use use FIGMA in our upcoming projects. Can you please let me know if you have some discounted plans available for non profit organization? We would like subscribe for it. Thanks and Regards, Vijetha Mehta Product Manager, FieldsData
I am working with Figma for about 3 years and it is a wonderful software. Speed used to be awesome in the beginning. It changed after a while and now it is really a pain to open files, select frames and resize areas. It starts blocking my work. You read always “Empty the cache...” I did but no change. Please dear Figma team realize that there is a problem that needs your attention.
Hi, I created an interactive component that worked fine until one week ago (more or less). Now, when you hover on it the font changes and shows the message “Some missing fonts were replaced”
Hi, I’m trying to change e-mail that I am using for my figma account to the one from which I am writing but even after following the steps several times I keep getting below error and I am stuck with the old e-mail. Any support anyone? :(
Hello,When using the text tool, I'm unable to get text to manually hard return, or skip to next line when hitting enter. I have text with hard returns in document that I previously created on both Windows and Apple computers, but even those blocks of text will not hard return when the cursor is placed inside when using browser on fairly new Samsung Android tablet. Text returns work in other applications (google docs, notes, web forms, etc) Any suggestions?
In Dev mode if I want to just copy one or 2 lines from the style code block, it’ll paste it out as just a unicode instead. I’ll have to use only the copy button to copy all the code for it to work - which is overkill and a waste of time for what I need. This never use to be the way.
I’m trying to create a button, using my variables for correct coloring on themes. My actionable icon hover is connected and showing up correctly However, when I place this component in the button lock up - the surface/default changes from light to dark - even though no variables modes are set on the component/frame/or section. No variable modes applied (on component/frame/or section) And I know this is true since my actionable icons component lives within the same frame & section and is appearing as wanted How do I fix this? Please help
Yes I know this topic has been raised before, but I would like to raise it again, since it is breaking the core interaction in my design system. Is Figma even aware of this issue? Since the last discussion about it is ~2years ago, and this issue still exists. Steps: Create a Button component set with 2 variants: Default, On Press Add interactions in the variant: “Default” → While pressing → Change to “On Press” Insert an instance of the “Default” button into a new Frame Add interactions to the button: On Click → Open overlay. Check the “Close when clicking outside” box. Test the prototype Results When you click the button, the button change to “On Press”, the overlay opens, but when clicking outside the overlay to close it, the button does not reset back to “Default”. Expected: The button should reset to “Default”.
Всех приветствую! Открываем топик для общения на русском языке. Пишите свои вопросы, пожелания, идеи. Официальное сообщество в России Figma Moscow Телеграм канал с анонсом всех новостей Мероприятия, которые будут по Figma, параллельно официальному сообществу буду анонсировать тут: Мероприятия по теме Figma (RU)
In Figma Make, how do you delete extra or empty files from the code tree? I can’t delete them or prompt the AI to delete them successfully. I’d like to make sure they do not confuse future prompts.
Find answers, learn more.
