Add searchbar to variable panel
Meghan_Rose1
When you have alot of variables it would be nice to be able to search for specific things
IraX
  • 145 replies
  • June 24, 2023
I’m at my vote limit but yes. Should account for both name and value.
Should have an search option which selecting an instance in component, as while changing an instance of an icon component set variable i have to manually look for that icon name, or atleast it should have an option to sort by name option in variable instance selection
Shawn_Willings
Request to add a search feature to the variables panel. I am using it quite extensively and getting to the right variables is a bit cumbersome at the moment. Since the naming of variables usually is built around a convention then a search feature here would be very effective.
See the top right corner of the screenshot below.
Figma-request03
It would ideally have an autocomplete/live search functionality. This might already be in the works, but it wasn’t in the “coming soon” section of the Beta Features page. This isn’t really a feature anyway, but I thought I’d put it on the radar.
Thoughts?
Adam_Stepanek1
It would be very useful to be able to search in Local variables window. We are using Local variables to add translations and it’s very difficult to fix a particular translation when there are hundreds of them. You have to manually scroll through the phrases and look for the one.
I know there was a similar thread here Can you add search to variable manager but it’s closed now
Celine_
  • 3733 replies
  • October 25, 2023
Hi Shawn_Willings,
Thank you for your suggestion. I’ll pass along to our team for consideration 🙂
vsathishkumar
Much need option, it is very difficult to find variables when we have a lot of variables and themes.
Matthew_Sear
Me and my team are working on a plugin to resolve this issue, would be great to get your feedback on it?
pixellink.design
Satterwhite_Carl
Agree 100%, I was just getting ready to request the same exact thing.
In our case, we’re building out a pretty intense theming structure, and it’s quite cumbersome to have to scroll the variables sidebar to find your components and associated variables every time.
Additionally, a shortcut command to collapse the component variable tree in the panel (like opt > l) in the Pages panel.
Thanks for the consideration.
Sophie26
  • December 13, 2023
The ability to search for variables within the local variables
Tommy_Wagelaar1
Yes please. Ideally it sorts live through the results while you are typing, as if it was a filter or something.
John_Posey
To effectively manage variables we need a way to search and highlight where they are used. It’s very difficult to keep track mentally where they are used while testing different options.
  • February 14, 2024
Yes! please add the search! Why is it missing in the first place?
Simon_Loizeau
A big yes for that feature. I can’t imagine that Figma won’t offer this feature in its very next releases
The_Vinh
  • April 1, 2024
Hello, can you add a search bar in Variable, because it is now widely used for naming tokens, so there are many variations. It’s very difficult to search and edit without a search bar.
Raphael_M
  • 394 replies
  • April 1, 2024
Hi @mods, can you make this a share an idea type of post if @The_Vinh agrees? Thanks.
  • 4873 replies
  • April 1, 2024
This feature request already exists on the forum and you can vote for it here: Add searchbar to variable panel.
Raphael_M
  • 394 replies
  • April 2, 2024
haven’t seen that. Thanks
Ugo
  • April 9, 2024
Yes it is very hard and painfull for our little eyes
Chloe_Mosselmans_Ismaily
I wish there was an easy way to sort local variables alphabetically per mode instead of manually moving them around one by one.
Mel7
  • April 11, 2024
Are you able to apply a search function under the selection color of a file. Below is an example where we have like areound 50+ colors in a frame/mockup and no way to search fast the color/s you want to replace or update.
Patrick_Hansen
Is there any traction on any of these features to search or manage variables easier?
I’ve been hoping this feature would have made it in after beta.
MG17
  • 18 replies
  • September 12, 2024
Push. Please add a search. Should be a basic feature for such a powerful tool.
MG17
  • 18 replies
By the end of the year, we will have at least 2,000 variables multiplied by at least four modes. So 8,000 values. Finally make sure that this tool becomes usable.
Tyler_Aikey
  • September 20, 2024
It honestly blows my mind that this isn’t a feature yet, my use case is simple: I need to change the variable value on a specific token variable I’m using on a component, currently there seems to be no way to alter that variable in the fill options menu, so I make note of the variable and go to find it in the variables menu to update the color.
The problem I’m experiencing is when I go to find this variable in the variables menu there is no search option! So I’m forced to scroll our list of hundreds of token variables until I find the variable I’m looking for. Adding a simple search into the variables menu would alleviate this problem.
Shreya_Patel1
I wanted to share a suggestion regarding the accessibility of variables when working with files that contain multiple variables. Currently, when we need to locate a specific variable like “Switch,” we have to manually scroll through the entire list of variables, which can be time-consuming and inefficient.
To improve this process, I suggest adding a search option within the file interface. This feature would allow users to quickly and easily find the specific variable they are looking for, streamlining the workflow and enhancing productivity.
I believe this improvement would be beneficial to many users and help us work more efficiently.
And and I would appreciate your feedback on this suggestion.
figma #FigmaCommunity @figma_admin variable #search #bugs feedback FigJam libraries team-libraries Ask the community Share an idea General Discussion Questions Feedback #
