IraX
Power Member
June 24, 2023
I’m at my vote limit but yes. Should account for both name and value.
August 22, 2023
Should have an search option which selecting an instance in component, as while changing an instance of an icon component set variable i have to manually look for that icon name, or atleast it should have an option to sort by name option in variable instance selection
Shawn_Willings
September 29, 2023
Request to add a search feature to the variables panel. I am using it quite extensively and getting to the right variables is a bit cumbersome at the moment. Since the naming of variables usually is built around a convention then a search feature here would be very effective.
See the top right corner of the screenshot below.
Figma-request03
It would ideally have an autocomplete/live search functionality. This might already be in the works, but it wasn’t in the “coming soon” section of the Beta Features page. This isn’t really a feature anyway, but I thought I’d put it on the radar.
Thoughts?
Adam_Stepanek1
It would be very useful to be able to search in Local variables window. We are using Local variables to add translations and it’s very difficult to fix a particular translation when there are hundreds of them. You have to manually scroll through the phrases and look for the one.
I know there was a similar thread here Can you add search to variable manager but it’s closed now
Celine_
Hi Shawn_Willings,
Thank you for your suggestion. I’ll pass along to our team for consideration 🙂
vsathishkumar
Much need option, it is very difficult to find variables when we have a lot of variables and themes.
Matthew_Sear
Me and my team are working on a plugin to resolve this issue, would be great to get your feedback on it?
pixellink.design
Satterwhite_Carl
November 17, 2023
Agree 100%, I was just getting ready to request the same exact thing.
In our case, we’re building out a pretty intense theming structure, and it’s quite cumbersome to have to scroll the variables sidebar to find your components and associated variables every time.
Additionally, a shortcut command to collapse the component variable tree in the panel (like opt > l) in the Pages panel.
Thanks for the consideration.
Sophie26
The ability to search for variables within the local variables
Tommy_Wagelaar1
January 23, 2024
Yes please. Ideally it sorts live through the results while you are typing, as if it was a filter or something.
