Shane
Feb 26, 2021 6:30 PM UTC
LAUNCHED: State management for prototypes
Just struck a pretty simple use case/scenario where I need the component to reset it’s state when I leave the frame. This has been touched on elsewhere, but this is such a common and key use that I thought I’d put it in it’s own thread.
Scenario:
I’ve got a dropdown menu with three items in it, with each item changing what columns are visible in a table and some other control states. I have three frames, each with a view of the table setup as it should be, and want to use the dropdown items to navigate between the frames - basically faking the table state change. All of this works perfectly, however when I navigate back to a previous table view state, the dropdown component is already in it’s open state - not what I want.
Current workaround: none that I can come up with (other than not using interactive components at all for this, and just using multiple frames for the dropdown open/closed states as I would previously)
Suggestions:
  1. Have a “reset component on leaving this frame” setting for instances of a component on a frame - useful for this situation and others, but needs to be a setting so that components that should keep their state between frames can do so (light/dark toggle maybe? Something like that).
  2. Do it all in a single frame, with the dropdown component changing the the state of the table component - no frame navigation required. Would work nicely for the particular use case I’m working with here, but not sure it would solve all similar situations.
  3. Do both 1 and 2. This solution is my preferred solution 😉 😆
EDIT:
Other threads that relate:
Crystal5
Jun 6, 2022 3:57 PM UTC
I can’t get it to reset either. @Figma_Support please help.
Jake_Albo
Jun 7, 2022 6:04 PM UTC
Agreed. Exactly what I am trying to build and it just created a MAJOR roadblock
Frannn
Jun 9, 2022 12:55 PM UTC
+1 on this. I’m working on an app intro, basically a looping sequence of a few animated components using “after delay” interactions and smart animate (it’s awesome what can be done with Figma these days, by the way). Works fine on a first round, shows components in their final state after on. Kind of a show stopper.
Lauren_Aldrich
Jun 9, 2022 4:45 PM UTC
Does anyone know how to elevate/change this to a topic that can receive votes? Or how to get @Figma_Support to chime in or help?
burakkuyucakli
Jun 16, 2022 10:26 PM UTC
Aram_Brazilian
Jun 17, 2022 3:37 AM UTC
Same problem.
I open a drop-down menu on a frame, click a link in it to a different frame, and then when I click a link back to the original frame the menu is stuck open from before.
Honestly, this (interactive components) is the main reason I was switching to Figma from Sketch + Invision - if I am back to creating a static frame for every state, then I might as well stick with Invision…
Tom_Byers
Jun 17, 2022 9:45 AM UTC
+1 from me.
There’s a frame in my prototype that when a user navigates to it, I want everything in its base/starting state, regardless of what they might have interacted with previously.
Michael_Patrick_Ayobami
Jun 22, 2022 8:04 AM UTC
This problem still persists. it is sad I seems stuck, found a couple of workarounds but it doesn’t do it for me.
Kay5
Jun 23, 2022 5:31 PM UTC
+1
a really needed feature
Nico008
Jun 23, 2022 9:36 PM UTC
+1
Same issue. It would very very useful
