Mark_McIntyre
Apr 17, 2024 10:09 AM UTC
Allow percentages for line height
Firstly great job Figma Font variables are here!!!
The only thing missing is the use of percentages in the line-height property.
You can not use a percentage in the line-height as it only accepts variables that are a number type.
Although the variables for line-height caters for pixel (absolute) line-heights (10,12,14)- it does not accommodate relative line heights.
In other words you can’t use percentage variables for line heights that are a percentage of the font size (100%, 120%,150%).
Interestingly …You can use a variable for letter-spacing ( which accepts a number variable - but reads it as a percentage) - the challenge remains that line heights by default are absolute not percentages - even though you can input a percentage.
Percentages allow greater flexibility and less calculations
Word around would be to allow formula in a variable
e.g. =[variable] * 1.5
Or figuring out a way for the line height to be toggle between absolute or relative application of the number variable.
Richard_Whitner
Apr 18, 2024 2:14 PM UTC
Definitely needed. Don’t particularly care about the format (eg. 1.5 vs 150%)
Franni
Apr 19, 2024 9:30 AM UTC
YES! Just working on that and I’m so confused they forgot about that…
Slava_Bronevitskiy
Apr 19, 2024 10:59 AM UTC
This release is awesome, but doesn’t work as intended for line height when expressed in % (not sure about others, but along my whole career this was the only useful and the only used unit).
Is there any chance this feature will get a follow-up to make it complete?
impactby.design?ref=nI
Apr 19, 2024 11:09 PM UTC
💯 This would be really helpful!
Expansion on Why It Would Be Helpful
I’m a Product Designer working closely with developers to update our hard-coded UI using a design system.
  1. Emulating our design system’s code structure is such a boone for design-dev synergy. Using variables in Figma has brought me closer to parity with the system, improving efficiency and collaboration.
  2. Variables help me evaluate the effectiveness of our design system structure and identify areas for improvement. I enjoy using variables for the same reasons devs do — fixed values result in a lot inefficiencies when you are working with a complex UX.
  3. Using pixels makes line-height values dependent on font size result in numerous variables to maintain consistency. Using percentages would streamline this process and allow for more flexible adjustments based on context.
I have 7 font-sizes within my system. Then, I have 3 stylistic choices for line-height for each of them (tight, base, loose) that can be chosen based on what’s needed in-context. If I am using px, this would result in about 21 variables to cover my whole system. If I ever wanted to update my font-sizes: I would need to update all the applicable line-height variables. Percentages allow for me to have just 3 variables — and these variables would not need to be updated if I were to update my font-sizes.
  1. The line-heights are specifically important to me because they are now the only Core Token in my design system that I can’t use my Figma variable system for 😭
Jannis1
Apr 20, 2024 3:11 PM UTC
Great new features but this is 100% (Badum tss) missing!
Ivan_Khoma
Apr 22, 2024 9:17 AM UTC
yes, please
Manu_Garzaron
Apr 22, 2024 4:20 PM UTC
Yes, please 🙂
Julia_Mnizhek
Apr 22, 2024 4:45 PM UTC
Much needed in my team too 🙏
Ross_Gehm
Apr 22, 2024 8:36 PM UTC
I’ll add that this would be very helpful. Percentages all the way!
Nathan_Peters
Apr 22, 2024 9:50 PM UTC
Agree this would be super helpful!
If the Figma team wants to avoid adding units or percentages into the variable itself, maybe there could be a select dropdown beside the line-height field (or letter-spacing field) that lets you select from px and %.
