Mark_McIntyre
Allow percentages for line height
  • April 17, 2024
  • 198 replies
  • 25490 views
Firstly great job Figma Font variables are here!!!
The only thing missing is the use of percentages in the line-height property.
You can not use a percentage in the line-height as it only accepts variables that are a number type.
Although the variables for line-height caters for pixel (absolute) line-heights (10,12,14)- it does not accommodate relative line heights.
In other words you can’t use percentage variables for line heights that are a percentage of the font size (100%, 120%,150%).
Interestingly …You can use a variable for letter-spacing ( which accepts a number variable - but reads it as a percentage) - the challenge remains that line heights by default are absolute not percentages - even though you can input a percentage.
Percentages allow greater flexibility and less calculations
Word around would be to allow formula in a variable
e.g. =[variable] * 1.5
Or figuring out a way for the line height to be toggle between absolute or relative application of the number variable.
Jonathan_Zazula
April 17, 2024
Is there a way to use % based line heights with Figma variables?
Patrick_Sobrak-Seaton
April 17, 2024
Seconded! This would be very helpful!
Seth_Bowers
April 17, 2024
1000% Second! - best practice on the code side is unitless numbers. Which we translate to percent in Figma. (1.5 = 150%)
Christian_Klose
I just asked myself the exact same question. It seems that it does not work - very sad!
Equinusocio
April 17, 2024
The native typography variable has different issues that make it another half-implemented feature.
  • We can’t use variables inside line-height since we can’t use % values (only numeric variables work on that field, so no % allowed)
  • Another big issue for us is that we can’t hide typography values inside other non-typography-related fields. Or, in other words, we can’t show typography variables only for text’s fields since the option is not present inside the list:
    CleanShot 2024-04-17 at 18.52.39
Barry_McMillan3
Agreed, we need percentage based line-height
lukeratc
April 18, 2024
+1 from me for percentages and for enabling formula.
pietrogregorini
I totally agree, using a single number is neither used in code, most of the time it translates in 1.5 for example.
Marcus_Scheller
April 18, 2024
Much needed.
Kenneth_vest_Knudsen
+1 (million) from me! once i read the news i expected this to be shipped with % support
