Mark_McIntyre
Apr 17, 2024 10:09 AM UTC
Allow percentages for line height
Firstly great job Figma Font variables are here!!!
The only thing missing is the use of percentages in the line-height property.
You can not use a percentage in the line-height as it only accepts variables that are a number type.
Although the variables for line-height caters for pixel (absolute) line-heights (10,12,14)- it does not accommodate relative line heights.
In other words you can’t use percentage variables for line heights that are a percentage of the font size (100%, 120%,150%).
Interestingly …You can use a variable for letter-spacing ( which accepts a number variable - but reads it as a percentage) - the challenge remains that line heights by default are absolute not percentages - even though you can input a percentage.
Percentages allow greater flexibility and less calculations
Word around would be to allow formula in a variable
e.g. =[variable] * 1.5
Or figuring out a way for the line height to be toggle between absolute or relative application of the number variable.
Elias_Tinchon
Apr 23, 2024 6:32 AM UTC
+1 this is absolutely necessary!
Joe_Mallory-Skinner1
Apr 23, 2024 8:43 AM UTC
So true.
Annoyingly, when using a number variable for letterspacing it changes from % to px…
taras-stoliar
Apr 23, 2024 11:15 AM UTC
Feature is there! But halfway done. Not using cause of missing % values. Please implement it! +1 here
Ole-Marius_privat
Apr 23, 2024 1:16 PM UTC
+1 here as well. Very much needed. Frankly puzzled that this is not implemented from get go.
ThatOneGuy
Apr 23, 2024 1:20 PM UTC
I would love being able to use unitless numbers as well. Then the exported variables will match the required format in code.
Julian_Kovalsky
Apr 23, 2024 4:49 PM UTC
I would love this for Letter Spacing also.
Jon_Bueno1
Apr 23, 2024 9:06 PM UTC
IMO feature is not 100% viable until this is added. Frankly, I plan to put it’s use on hold until this is added.
Alice_Holm
Apr 24, 2024 9:30 AM UTC
+1! Need % for both line-height and letter-spacing!
Trisha_Paredes
Apr 25, 2024 2:36 AM UTC
%s are much scalable and lessens maintenance
Jon_Cho
Apr 25, 2024 3:01 PM UTC
How are you getting the letter-spacing to use percentages? It just converts to px for me.
