FIX rolling out: Library styles not displaying properly
Show first post
Nick_M
  • February 9, 2023
Wow, okay, I thought I was going crazy. But it looks it’s happening across the board at the moment.
I have the same problem 😦
1 hour ago everything was fine, I went out to have dinner, came back - and then everything broke down…
Hope everything will be fixed soon 🙏
Chase89
  • 7 replies
  • February 9, 2023
+1 same here
August_Browning1
I’m sure there is probably an obvious solution but it’s not coming to me right now. None of my local styles come up when I click on the 4 dots. I have been using these styles in this file for several days but today it just stopped working. Restarting figma did not work. Searching for the style names returns no results.
Screenshot 2023-02-09 at 3.19.27 PM
Kim_McKinnon
Same here…
I’m also having this same issue with both color styles and type styles!!
Right when i have to make changes and present the file!! 😢
This is a problem for me - has there been anyone who has seen this resolve or found a way around it? It’s really frustrating and I’m having difficulty completing work.
Having the same issue here.
Boris_Otasevic
All styles not working - both local and from libraries.
FIX this please.
August_Browning1
Same here…
And I was flagged for spam by the bot police from figma LOL.
but yes, please fix this.
Jackie_Gies
I’m having the same issue… has anyone been able to fix?
Grace_Lee1
My published color styles are not showing up in my figma - you can see that the library is sync’d bc of the name and if I try to open the styling libary to change to another existing color style - it is blank
hernan_lozano
Is anyone having issues with the design panel on Figma? It doesn’t load the color styles anymore (these are local not from a library), I already restarted Figma several times, also my computer but it doesn’t work. It was working just fine some minutes ago and I can’t seem to find a solution for this. The design panel isn’t even working. When I select any element the properties usually appear on the right panel but now it’s all blank. Any advice would be appreciated!
Boris_Otasevic
Same problem here. Both local and library styles dissapeared.
Leotan
  • February 9, 2023
Same issue. Did this happen about 30 minutes ago for everyone?
Kacey_Diehl
I guess Twitter is yelling at Figma to fix it. Not sure if there is much we can do.
xMOx
  • Active Member
  • 24 replies
  • February 9, 2023
Also here is the other part I was talking about the Design Tab not showing controls after selecting a Frame
Lorenzo_Franchini
“We’ve identified the issue and a fix is being implemented.” It’s happening!
Paris_Andricos
I am having the same issue, all text and color styles are empty
Michael_Kuhlmann
same problem for my team here. currently detached objects from styles and manually adding hex codes, which i’ll change back to styles once they’re working again
Sam_of_thunder
having the same issue on mac desktop, glad to know it’s not just me — really slowing down my workflow
Stacy_Esposito
John_Morr
  • February 9, 2023
Same issue here, colors not displaying even after enabling the library
