hi i lost access as a owner of this file: linkand everybody from my team lost accsess too.can you please help? i tried to contact the support form but you sent me this: Thanks for reaching out! It looks like you're contacting us from a Starter account. Customers on this plan receive support through our Community Support Forum and Help Center.
Hey everyone! Our team has built a multi-brand design system that supports three different brand themes, each with both light and dark modes. All our icons are created as unions. This helps preserve the color override when an icon is swapped inside a component. For example: all icons use the “icon” color variable by default, but within a success inline message component, the icon is overridden with the “icon-success” color variable (green), as the icon should always be green in that context. Swapping, say, a checkmark icon with “icon-success” applied for a shield icon retains the correct “icon-success” variable. So far, so good. However, when we re-theme the inline message component from Brand 1 to Brand 2, the icon switches to a different brand-specific variant from the icon component set. Here’s where things break: in component instances, the color override (“icon-success”) is lost during this brand switch, and the icon falls back to the default “icon” color variable — which in our c
I want to make a prototype where something changes when user scrolls content. I want to keyboard collapse when user starts scrolling content, but it’s impossible to do with drag action. Or it feels unnatural Or am I missing a way to do it with existing tools?
I created this shape from a mask (see left panel) and want to turn it into a vector. However, flattening it just gets rid of the mask like so: And all the boolean operations like union or intersect fills the shape with the stroke color: How do I work around this? Thank you
Please can we get percentages for variables? We can use percentages manually, but we can’t create a percentage as a variable. This would speed up my design to dev process tenfold, and considering we can already use percentages in the design, why disallow it in variables? An example is I want store values for line height and letter spacing as percentages which behave responsively/dynamically, so when creating type variables I don’t have to do manual calculations, store 10+ letter spacing/line height values based on which font size they will be used with and hope I never change the font size variable in the future.
Every time I paste the copied YouTube link where the YouTube video is supposed to start at a specific timestamp it starts from the beginning. When I paste the link into the browser the video starts in the correct spot. Has anyone else experienced this and found a way to get the link to start at the proper timestamp? Figma Desktop App version 125.5.6 MacOS 15.5
Would be great to have a move to end or move to front option in Figma slides. If the deck is long, it can take forever to drag slides to the end (most common, editing things out of presentation into a “outs” section) or beginning of a doc.
Here is our published file It supposed to be a free. But Figma added some link to purchase. We are not trying to sell it. How to make published file free? Why Figma redirecting to third party service? The file was published as free for community https://www.figma.com/community/file/1526612389723912224/ui-elements-for-e-commerce
In my company, we have strict security policies, and I need to ensure compliance before using MCP. Specifically, I would like to understand where the server is initiated when the get_code_connect_map command is executed. Does it run on my local machine, or is it hosted on Figma's servers? Any clarification on this would be greatly appreciated!
So i was giving a project to create an app that views figma files, i did so, placed the app in figma developers portal where i got an id and secret code, i did everything and tried integrating figma api into my backend, ran everything, i got linked to figma successfully, got the token, but when i try to access my projects or files i get an error 403, invalid token, but it was successfully linked too
I am having trouble with a keyboard shortcut, have any of them been changed? Ctrl +shift + K was opening up the window to insert media like images but no longer does so. Instead it opens a window to search or ask a question, anyone familiar with this issue, up until this point haven’t had an issue with any of the shortcuts.
I have an icon and text in an autolayout. The text truncates as soon as I drag the frame smaller. If I have several of these frames in another autolayout next to each other I want the icon to disappear as well PLUS the text to truncate. Is there a way to do this? Also a workaround.
At noon, everything was working fine when I was using one of my documents. However, suddenly a pop-up window appeared saying “Out of memory” and prompted me to open recovery mode. Since then, I noticed something unusual: this particular document has significantly less content than my other files, yet it keeps showing memory issues. Even after I deleted some elements to reduce the load, the file still reports that it’s over the content limit. Strangely, a single text box with just two words can take up about 0.2% of memory, and the memory usage keeps fluctuating between 0.1% and 0.4%. Whenever I try to make any small changes, the document crashes with an “Out of memory” message and forces me to reload the page—even when the memory usage indicator shows only 29%. This file is very important to me. Please help me resolve this memory issue—I’d be incredibly grateful!
I have a text component in Figma. I want to reuse this component, but I need the font to be smaller. If I manually change the font size, when I switch the variant, it restores the original font size. I need the text to keep the size I want for this specific context.
Find answers, learn more.
