Inverted Boolean Property
  • November 9, 2022
  • 5 replies
  • 3826 views
woodywoodsta
Third suggestion for this feature, since it keeps getting closed.
At the moment you can show and hide a layer based on a true and false property value respectively, but you cannot do the inverse (show a layer if a boolean property value is false).
A common class of use cases for this is when you want to have something in your design be replaced if it is hidden (i.e. layer A is hidden by means of the boolean property, while layer B is shown instead).
Previous suggestions:
drewcovi_usb
not that this is an awesome idea, but you can always hack this by using auto layout embedded in a frame with “clip content”. hiding the visible item would cause the hidden item to collapse into the frame and become “visible.”
woodywoodsta
This covers only one of many use cases.
  • 4873 replies
  • January 24, 2023
Until this is implemented, as a workaround, you can achieve the desired result with the boolean exclude operation.
I wrote about it here:
Check out the live demo:
woodywoodsta
Not a bad idea, but this makes it quite difficult for developers to grep what is going on with the designs, especially if the item to exclude is a complicated layer.
  • April 24, 2023
