Inverted Boolean Layers
Phil_Larsen
I really like the new direction for properties and variants. There was a bit of a learning curve, however, I see the potential in creating more powerful components without the need for as many variants.
I am running into an issue where I want certain layers to be visible on the true value for a Boolean, while turning off some layers on the same state of the boolean property. Right now I have to make a variant to achieve the desired result. I’d rather be able to set it up in the fewest variants possible.
woodywoodsta
I have just started using this feature, and immediately I needed the inversion of the boolean value. What a strange decision to make!
I imagine that this was done so as to not overlap with the instance swap, but the instance swap doesn’t quite do what inverting a boolean does so it leaves a gap in use cases.
woodywoodsta
  • August 23, 2022
