Frames no longer manually resizable?
Merzuk
First of all big thanks for Figma for providing many great updates, especially for prototyping mode. But not all new updates are good, at least not for me.
I have been resizing frames manually (typing numbers in the Width, height box) since forever. But now it seems I am no longer able to do that, or suddenly I am doing something wrong.
This is what happens when I click on the height box to resize the height.
Usually I click here and change the numbers, if I want to increase the height for 16 pixels, I add two numbers or 849+16.
Or sometimes when I work on mobile size with 16px margins, I quickly draw another frame inside and immediately type 343 width size for that frame and then centered it.
Please tell me this is a bug, not a feature.
Greetings
Best answer by Ryan_52
Thank you everyone for your reports of this issue. We are pleased to inform you that the fix has been successfully released!
Please refresh Figma to ensure that you are using the fixed version. If you continue to experience the issue, please let us know and we will flag it down for further investigation.
  • June 21, 2023
Before the last update, we could use the’ +’ or ‘-’ keys to sum or minus the width and height fields. Now, with Variants, ‘+’ key has been remapped to use variants and can’t sum. Is there a way to include ‘+’ in the text so we can sum pixels and adjust width and height?
Thank you
Merzuk
  • 12 replies
  • June 21, 2023
Same problem here
Ryan_52
  • 382 replies
  • June 21, 2023
Hi @Merzuk I’ve checked this from my end but are still able to manually add values for the width and height to resize the Frame.
Are you seeing this issue in the browser or desktop app? Maybe try clearing your cache and see if that helps resolve the issue from your end.
Merzuk
  • 12 replies
  • June 22, 2023
Sorry Ryan, I missed one important detail and that’s ‘+’
If I want to calculate two numbers and when I press ‘+’ then this library popup appear.
I have cleared cache and restarted figma, this issue is still there.
Very much similar to this issue
https://forum.figma.com/t/cant-use-to-sum/45684/2
Ryan_52
  • 382 replies
  • June 22, 2023
Thank you for clarifying that though I checked in the desktop app and browser again and was able to calculate two numbers using ‘+’ in the width and hight fields.
Possibly check your keyboard layout in the ‘?’ icon in the bottom right of the file and then select “Change keyboard layout”. When I enter in the ‘+’ value I hold shift down but do notice not holding shift which is ‘=’ will open the library popup.
IraX
  • 145 replies
  • June 22, 2023
@Merzuk — From looking at your screenshot, you’ve selected the variables icon which produces the panel shown in your image. Just select the input like we always have and you can still do everything.
Merzuk
  • 12 replies
  • June 22, 2023
@Ryan_52 @IraX
I am using desktop client. I don’t know about the keyboard layout. On system level I am using Croatian on Figma I have checked unter ‘?’ icon and it the keyboard layout is Generic.
For me the plus sign still does not work in input boxes. I’ll try to upload video showin when it happens and you’ll see that plus sign works fine when I am typing inside the frame as a text. Ignore the asterix sign.
Merzuk
  • 12 replies
  • June 22, 2023
Another update. Minus ’ - ’ works just fine. Only plus ’ + ’ brings this popup.
I’ll record a video with my phone camera. I really don’t know how I am the only one with this issue.
In order to make plus sign work, workaround is to copy from one place and paste it then in the input box, which is inconvenient.
Ryan_52
  • 382 replies
  • June 23, 2023
It seems that the issue might be related to the keyboard layout you have configured, possibly at the OS level. The Croatian keyboard layout differs from mine, as the key that includes ‘+’ on your keyboard also includes ‘=’ on mine. To enter ‘+’, I need to hold the shift key. Maybe test switching your keyboard layout out to US at the OS-level.
Hampus_Svallfors
Same problem here. Using Swedish keyboard layout.
My top two keys next to Backspace are inverted compared to a US layout.
If I change my Layout to US Extended, + works the same as for @Ryan_52
jonik
  • June 26, 2023
Since the variables update I can longer add up to x/y position or width/height values with the + key, since it now opens up the variables search. In the screenshot, I tried 142+24 but that apparently doesn’t work anymore.
Screenshot 2023-06-26 at 10.45.54
Screenshot 2023-06-26 at 11.23.12
When pressing the “+”-button in the H-box Figma opens the variable menu. This seems broken.
Norman_Fiser
You can also type in double minus “–” to get a sum
Ryan_52
  • 382 replies
  • June 26, 2023
Thank you everyone for raising this, this information has been passed to our engineering team and they are investigating further.
Hello!
I noticed that with the new update, I can’t use the “+” sign in calculations. Instead, the shortcut for the Library opens up. For example, if I want to resize the whole frame, which is 2000px in height, I want to do this: “2000-1000+128”. After the update, I can only do “2000-1000” and then go back and add the “+128” to the height. If I want to do the whole calculation, it opens the Library for variables. Is this working as intended or not?
Kenneth_Runge
I have the same issue using a Danish keyboard layout.
I hope this will be fixed soon, it’s really annoying when you’ve been used to this working since forever!
Filipa_Pereira
When I’m designing I usually use the height and width field as a calculator 🧮
If I have a 200px frame and I want it to be 220px in the height/width area I add to the 200px + 20px - Figma will calculate for 220px 🎉
With the new update dividing (/) and subtracting (-) is ok, but adding (+) is not!
**When I use the sum it always opens the Search area **
Is anyone else with this stress?
Filipa_Pereira
Screenshot 2023-06-29 at 16.10.32
Ryan_52
  • 382 replies
  • June 30, 2023
Merzuk
  • 12 replies
  • June 30, 2023
Thank you guys for listening and quick fix. I just checked and can confirm it’s working on my side.
  • July 7, 2023
Thank you so much for fixing this!
  • July 21, 2023
