Hey there! 👋🏼 For over a week now, it seems like empty rows from the spreadsheet are being included when assigning properties to template layers. As a result, I’m getting over 1,000 assets created with no content (since the rows have no information). That wasn’t the case a few weeks ago, when I created and tested the templates before sharing them with the rest of the team. I assume this is a bug, but I wanted to ask if you are working on solving this issue? Warm regards, Aleksandra
Some time before in Figma when I did a query on an endpoint: GET curl -H 'X-FIGMA-TOKEN: {token}' 'https://api.figma.com/v1/files/{file_key}' With many others fields the collaborators field was returned in the response where I could get information about the person's email, role and IDBut now I don't see such a field in the responseHas the response body changed over time?And is there an alternative that could be used to get collaborators?
hi there! I made some code layers and everything was working beautiful! after figma sites and make came out of beta, all the code layers started to glitch! Help! i tried to make a new code layer with the code and also glitching , what can i do? Thank you!
Is it possible to have a free Figma Design Seat account to edit projects for how many days? As a company, we have several Figma licenses, but we need to share projects with external parties who need to edit these projects. Is it possible for them to edit for free for a few days, or will we have to assign them a Full Seat license? Thanks
The position controls for a cell seem to disappear when using library components. When I use local file components, they are available.
i have been using figma make for my recent project, i have used it around 2 days . but now when i send a prompt it throws an error “ something went wrong try agin after some time” i have tried duplicating the file and waited for more time still the issue persist note: ( i am facing this issue after 2 days of usage it mean i have made around 300 prompts and more)
This what I keep getting after Iteration 273. I literally cannot do any other prompts!
以前までは添付画像の赤枠内をクリックした状態でコピーすることで、同じエフェクトをペーストして重ねがけ出来たのですが、最近は同様の動作では実現できなくなってしまいました。 エフェクトのコピペ機能は削除されてしまったのでしょうか?もしくは別の操作方法に変わったのでしょうか?
I faced this problem on and not off but couldn’t really find any patterns. Sometimes, figma make is hallucinating with my prompts and giving weird screens (replacing existing screens) and giving wild outputs. After some time or the next day, the problem is getting fixed. For sure, the problem is not with the prompt, the problem starts with the way it is reasoning it. If this can be fixed, it will be really good because the flow is getting cut quite often.
I’m a developer that was just given dev mode access to my company’s library. When I execute `figma connect` I get this error: Failed to fetch components from Figma (403): 403 Invalid scope(s): Please ensure that you have selected both the File Read scope and the Code Connect Write scope when generating the token. In the Getting started with Code Connect article it mentions this: Generate a personal access token with the Code Connect scope set to Write and the File content scope set to Read-only. However, this is not one of the scopes that are available to me when I create a personal access token. This happens even when I give all my available scopes the highest privileges. Does anyone know what I am missing here? Does my organization need to do something to have this scope show up here?
Find answers, learn more.
