Iasonas
Mar 9, 2021 11:02 AM UTC
Enable Assets search only for enabled libraries
Since a long time ago I have noticed that Figma allows you to search all your published components within the asset window of a file. The thing is that I want to search only within the localized assets of a file and not all. All other libraries are switched off, however, I still search across every file and this is really frustrating.
I initially believed that this was a bug that would be fixed, but 1 year later I see that nothing changed. I remember that Figma used to allow its users to search within different published libraries in a file - if they wanted to, not obligingly. Anyone else having the same issue and found any solution?
larissa
Mar 15, 2021 5:46 PM UTC
I am not sure if my problem is the same but it is frustrating and confusing to our designers as well, that they see components in search for libraries the have not enabled in a file. one would expect to see results for only the libraries that have been enabled.
John_Heiner
Mar 23, 2021 4:32 PM UTC
I totally agree. For large orgs with many libraries, this is not only unhelpful, but anti-helpful. Search should search your local file and the enabled libraries only.
Maybe instead of “Showing results from all libraries” it should be a link with text “Show results from all libraries” that only shows results when you click the link.
Dario_Stefanutto
Apr 20, 2021 3:50 PM UTC
I just posted a question about this. I totally agree. What’s the point in toggling a library if its components still appear in the search?
Travis2
Jul 15, 2021 8:36 PM UTC
Jumping in to reiterate what the others said - this feature is not only not helpful, it’s harmful. I work in a large company with dozens of different design systems scattered across various organizations, and when people are working from my design system I need them to stay there because those are the things that have been built for them. It’s a toolbox, with very specific tools in it - if a designer doesn’t find what they need I can’t have them rummaging around in their neighbor’s toolbox, right?
Steven3
Aug 18, 2021 11:32 AM UTC
I totally agree with Iasonas
Too often do I pick the wrong component because it is impossible to know what library the component belongs to by looking at the “search result”. And for people not familiar with our design system it is even more confusing.
Bump #Figma?
adiacone
Sep 15, 2021 5:11 PM UTC
Today I did two new things in Figma: I upgraded to a Professional plan and I started using libraries. 15 minutes later I’m reading this thread. That’s unfortunate. 😞
What’s even worse is that the search results show components from read-only libraries that I have no way of removing from Libraries. Am I missing something? Shouldn’t there be a way to do that?
EDIT: Ok, I managed to at least solve part of the problem, thanks to @Gleb: to remove the file from the Libraries modal, open the file, click Share, find your name in the list (using the browser search, because there’s no filter) click the dropdown and choose Leave. That is so counterintuitive…
Andrew_Parker
Oct 14, 2021 3:05 PM UTC
Oh gosh - this a million times. It’s amazing that a library that isn’t included in my project is featured in asset search.
It’s even more unhelpful that you can’t even see where those results are coming from - so if you search on “button” and there’s fifty components called “button” from design libraries that aren’t included in this project how are you supposed to tell which is the one you need?
Hannu
Nov 9, 2021 4:38 PM UTC
We have this exact same issue in our Figma.
My expectation: the search in the Assets-panel only finds the published components, for the libraries that I have enabled for the file in which I’m working on. Currently, I keep seeing published components popping up in the “Search…” results, even though I haven’t enabled the said libraries for the file. Note: these components do not show up under the “Results from all libraries” but in the same list/grid as all of the results.
Hannu
Nov 10, 2021 3:29 PM UTC
Oh-kay, apparently this is not a bug, but a “feature”: Why do I get search results from Libraries that I have not included in the project? 😓
If you see this and also think that the way that asset panel search results now show up isn’t helpful, please vote for this feature request: Enable Assets search only for enabled libraries - #6 by Steven3 🙏
Hannu
Nov 10, 2021 3:34 PM UTC
Joining the bandwagon and 👍 to what everyone said in the comments. My expectation: the search in the Assets-panel only finds the published components, for the libraries that I have enabled for the file in which I’m working on. Anything else is a distraction.
@ moderators (like @Gleb ): this get help topic thread also relates to this feature request (as it’s poster, Dario commented above) : Components from unpublished library show up in search results
I posted comments there first, before I found this feature request (and found the other similar topics on this same issue).
